Originally Posted by toan30
I had the same issue on my wifes 2008 sienna. It turned out to be a defective accessory belt idler pulley. As i was told this is a known issue. Toyota replaced the idler pulleys and the belt at no charge.
Thanks fo the diagnostic heads-up; appreciate it!
?Was the Sienna still under warranty? Reading the extended warranty I have from Toyota, they only cover lubricated parts.
Idler pulleys don't look too hard to get to, but there are
three. Will need to get my rubber-hose stereoscope out.
Actually, more probably will try to live with it until the weather warms up, then install new serpentine belt. Turning each by hand will probably reveal which idlers are bad - hopefully only one.
I noticed there is a push for a certain Goodyear belt; Gatorback ???
What's the special reason for using that one?
