Burning oil and error code P0420 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2010, 10:39 PM   #1 (permalink)
View baskervi's Photo Gallery
I have an '03 Camry with 180,000 miles. It normally burned about a quart every 2500 miles, but then it suddenly started to burn a quart about every 1200 miles. It doesn't drop any on the driveway, and I can't smell any bad exhaust fumes, the car runs great, and there isn't any smoke.
Yesterday, the check engine light came on, and I took it to Autozone tonightand was given an error code P0420. I understand this is because of emissions. My question is, is this a problem I want to repair? Given it's burning oil, is it likely that the catalyst system will continue to foul?
Thanks very much.
baskervi is offline   Reply With Quote
Old 12-15-2010, 07:03 AM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
My first guess is that the pvc valve is clogged, or sludge has blocked it inside the valve cover. Verify that the valve works and plow air into the pvc port/hole to verify it is not blocked.
If you keep burning oil like that, the cat will likely clog again.
gdanaher is offline   Reply With Quote
Old 12-15-2010, 07:31 PM   #3 (permalink)
View littleslim1474's Photo Gallery
That code doesnt have to much in common with with burning oil.
Your code is for your CAT converter took a shit. Could be your 02 sensors too
littleslim1474 is offline   Reply With Quote
Old 12-16-2010, 06:01 PM   #4 (permalink)
Toyota Parts since 1981
Gameroom cash: $148255
View DOHCammer's Photo Gallery
Burning oil will most definitely cause the cat to fail after a period of time. If he was on his original converter however, it was due to fail anyway at that kind of mileage.
05 Highlander V6 AWD
170K miles young
07 Camry SE V6 SOLD!!
TRD Dual Exhaust & Air Filter
DOHCammer is offline   Reply With Quote
