Right Side HID Keeps Shorting Out - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-16-2010, 10:52 PM   #1 (permalink)
Loving the camry =)
View skyxliner's Photo Gallery
I've had my HID installed for about 4 years now with relay harness and everything.
Just recently, my right HID would suddenly short out on it's own.
Scenario 1: Cold start, 2-3min of driving, it'll suddenly short out.
Scenario 2: I'd be driving and i'd hit a pothole or a heavy jolt and the right light goes out.
To resolve it usually, I just turn it off and then on again and it works perfectly fine. After the car's been on for awhile, it doesn't seem to short out anymore.
Question 1: is the issue a bad ballast or hid? or what parts do you guys suspect is the issue? I've checked it and nothing looks bad.
Question 2: i've always thought my light output wasn't as strong as some other people's HID, can a good versus a bad ballast produce a stronger light output?
skyxliner is offline   Reply With Quote
Old 12-16-2010, 11:01 PM   #2 (permalink)
'11 Camry SE
exclusive's Avatar
Gameroom cash: $305680
View exclusive's Photo Gallery
With HIDs it's difficult to pin point the problem without doing some tests. Try to swap ballasts around and see if the problem happens again on the right or happens now on the left. You could narrow it down to ballast or bulb this way.
2011 Camry SE
|| Click my car below to see my thread ||
exclusive is offline   Reply With Quote
The Following User Says Thank You to exclusive For This Useful Post:
my.rims.are.stock (12-17-2010)
Old 12-17-2010, 02:34 AM   #3 (permalink)
270hp = Happy Foot
Gameroom cash: $395545
View aznlunatic206's Photo Gallery
double check your connections, other than that im guessing your ballast is taking a dump. what brand is it anyways?
2011 Camry SE V6 Fully Loaded w/o Navi
V-HIDS 5000k HID Kit Low Beam, 3000k Nokya Fogs
20% Aegis Tint, 50% Front Windshield
Tein Solara Springs on KYB GR2's
aznlunatic206 is offline   Reply With Quote
Old 12-17-2010, 09:06 AM   #4 (permalink)
sxe-10's Avatar
Gameroom cash: $133154
View sxe-10's Photo Gallery
im having the exact symptoms as you are, to the T actually, this problem happens more frequent when its cold too. I've tried disconnecting the ballast and harness to re-do everything, but it makes no difference, so I kno its not the connections, I've had my ballast for 3.5yrs now on my car, so im guessing its time for a new ballast
sxe-10 is offline   Reply With Quote
Old 12-17-2010, 09:38 AM   #5 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
You're saying it is shorting, but do you mean the circuit is opening? How many fuses have you been through if it shorts constantly. Lucky not to have burned up the car.
gdanaher is offline   Reply With Quote
Old 12-17-2010, 10:37 AM   #6 (permalink)
View workaholic's Photo Gallery
+1. try swapping your ballasts around, then go from there.
workaholic is offline   Reply With Quote
Old 12-17-2010, 10:43 AM   #7 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $476710
iTrader Score: 12 reviews
View bandit's Photo Gallery
It may be the ballast. I had a similar problem but it was both HIDs. I found out it was the ground wire on my relay harness. The wire tubing for the ground wire was facing up and somehow, water got in and rusted/corroded the wire thus shorting out. When I took off the wire, water was flowing out. Ended up getting a new relay harness.
Take the ballast on the right side and swap it with the left. If the left side does it but the right doesnt, then you know its the ballast. No one will know the definite reason just by what you describe. You'll have to figure it out yourself with trial and error to try and pin point what is causing the problem.
CarDomain
