Timing chain or belt? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-17-2010, 11:51 PM   #1 (permalink)
Rockman59
View Rockman59's Photo Gallery
I am a first time Camry owner.....have an '07 LE with 27K miles. Does this engine have a timing chain or does it have a belt? And at what mileage should it be replaced?
Rockman59 is offline   Reply With Quote
Old 12-18-2010, 12:05 AM   #2 (permalink)
Gameroom cash: $197815
View Frodo65's Photo Gallery
All 3 engine flavors available in the current gen Camry use a chain.
Frodo65 is offline   Reply With Quote
Old 12-18-2010, 05:29 AM   #3 (permalink)
View Robert1820's Photo Gallery
Both the 2.4 and 3.5 use chains. Toyota has no recommended replacement interval. There are very rare instances of a chain guide wearing or a chain stretching causing noise. In anything close to normal use problems with chains are just not a concern.
Robert1820 is offline   Reply With Quote
Old 12-18-2010, 01:43 PM   #4 (permalink)
Gameroom cash: $303755
^ As said above, Toyota now uses timing chains. There is no recommended service interval for chains since they are expected to last the life of the engine.
Mike
Old 12-27-2010, 11:07 AM   #5 (permalink)
92 Camry 5S-FE
LittleWhiteBubble's Avatar
Gameroom cash: $115750
View LittleWhiteBubble's Photo Gallery
Does the 2003 4 cylinder have a chain also? From what I've read it does, but I want to be sure. I searched and I know the gen 6 does but I want to verify the gen 5 does as well. There is no listing in the gates manual for the 4 cylinder so I assume it doesn't use a belt.
LittleWhiteBubble is offline   Reply With Quote
Old 12-27-2010, 12:53 PM   #6 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
The 2AZ-FE, 2AR-FE, and 2GR-FE all use a chain. In the gen 5 the only 2 engines that use a belt are the 1MZ-FE and the 3MZ-FE
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
