2010 camry fuse problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2010, 04:37 PM   #1 (permalink)
View bemike's Photo Gallery
USA 2010 camry fuse problem
new to asking question hope i am in right forum, did not see newer camry forum.
i have 2010 camry se, i was checking out replacing taillight. while testing connector for the wire that is parking light versus brake light i touched ground and it shorted out parking lights. brake lights work. front and rear parking lights do not work. hazard lights work ok. does anyone know the fuse or what might have sparked. i have tested fuses under hood and that all seem fine. any help please.
bemike is offline   Reply With Quote
Old 12-22-2010, 05:09 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Read your Owners Manual and check the correct fuse under the dash, drtivers side.
Old 12-22-2010, 05:23 PM   #3 (permalink)
the manual is not clear when looking for parking light function, i had to check all fuses. if i knew exact fuse that would be nice. they all seem ok by using ohm meter. did not know if there was something else like a relay.
Old 12-22-2010, 06:29 PM   #4 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $455050
View Luna2's Photo Gallery
Try looking for the fuse listed as "TAIL Lights".
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is offline   Reply With Quote
Old 12-23-2010, 08:06 AM   #5 (permalink)
the fuses are under hood, not under dash. anyone seen the the in cased fuses that are about 4" long, those look ok too. thanks
Old 12-23-2010, 11:08 AM   #6 (permalink)
'07 XLE
Gen6
This is like a chat with a 6 year old.
Fuse #1, 15 amp (under the dash).
Power to it? If not, then there is another problem upstream........
Fuse ok?
The Following User Says Thank You to njerald For This Useful Post:
my.rims.are.stock (12-23-2010)
Old 12-27-2010, 04:45 PM   #7 (permalink)
thanks nj, found fuse in dash had blown. replaced fuse working now. sorry about the confusion on 2 fuse panels.
