Kenwood Sub/Hifonics amp help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-25-2010, 11:42 AM   #1 (permalink)
View greycamRy's Photo Gallery
Hey, i bought a 12 inch kenwood sub and a 400watt hifonics amp off a friend of mine. If I go out, buy the battery terminal, powerwire, speakerwire, and ground wire, is that all I need to hook it up? Will this work with the stock radio?
2007 Magnetic Gray Toyota Camry LE
BOMZ Racing SRI/6000k HID low beam/20% tint all around/Smoked LED Tail lights/Blue LED Interior Lights/Verde Designs Black 17" Rims
greycamRy is offline   Reply With Quote
Old 12-25-2010, 12:25 PM   #2 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
You need to decide how you want to hook it up to the radio/speaker...easy way is a simple line out converter and connect to rear speakers. Good luck!
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
The Following User Says Thank You to Tobeit For This Useful Post:
greycamRy (12-25-2010)
Old 12-25-2010, 04:43 PM   #3 (permalink)
hey tobeit, thanks for the reply. Are you aware if the stock radio has RCA outputs? And when you say "easiest way" will I still get good bass? Thanks. im a super noob at this stuff, so all info can help.
Old 12-25-2010, 05:43 PM   #4 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
^ No rca's ..
I have yet to ever see an oem unit with rca outputs.
Either use the level input on the amp if it has it , or get a simple line out converter and you should be fine
CamrySExxx is offline   Reply With Quote
The Following User Says Thank You to CamrySExxx For This Useful Post:
Old 12-25-2010, 05:46 PM   #5 (permalink)
Thanks for anyother great answer camryse. I will have to buy the powerwire, battery terminal, and the line-out converter, and then I should be good. :cheers:
Old 12-25-2010, 06:16 PM   #6 (permalink)
Just get a amp kit and it should have everything you need. You can get them online for fairly cheap. $30 will get u a nice 4ga kit from www.sonicelectronix.com
Old 12-25-2010, 08:55 PM   #7 (permalink)
Take it easy... :-)
Tobeit's Avatar
...except the line-out-converter. I am buying mostly at sonixelectronics as well.
Old 12-26-2010, 02:13 AM   #8 (permalink)
^ Oh ya, totally forgot about that :P
Sonicelectronix is good stuff, and good prices. Fast shipping. Bought from them numerous times and they are the only place I recommend for online shopping. Well for car audio and what not.
