Rear Bearing wont budge! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-27-2010, 03:41 PM   #1 (permalink)
View streakinrican05's Photo Gallery
I am trying to replace the right wheel bearing on my 2002 Camry (4 cyl, ABS).
I got the rotor and bearing bolts off just fine, but when i tried to take the bearing off it seems super stuck! like I said all the bolts are out and i've tried banging on it for quite some time with a mallet, but all i seem to be doing is making the front end of the bearing wobble around more while the end attached to the brake assembly just seems like its heat-fused to where it bolts in!
Any suggestions or steps i might have missed?
streakinrican05 is offline   Reply With Quote
Old 12-27-2010, 04:55 PM   #2 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
bearing puller or take the spindle off and take it to a shop and have them press it out.
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 12-27-2010, 05:15 PM   #3 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
agreed! honestly you're best option is to take it to a shop, unless you can find a quality bearing puller. even then, it's a crap shoot.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is online now   Reply With Quote
Old 12-30-2010, 01:56 PM   #4 (permalink)
View AlmightyCamry777's Photo Gallery
Your rear bearing is a hub assembly, you don't change the bearing inside, you change the hub for about $130. I did it a couple of years ago. the thing you want to change simply unbolts with 4 bolts and it looks like this:
http://www.napaonline.com/Search/Det...+59999+3999999
AlmightyCamry777 is offline   Reply With Quote
Old 12-30-2010, 05:18 PM   #5 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
If you have removed the 4 bolts holding the bearing hub assembly, then the only thing keeping it there is rust and gravity. Are we all talking about the same thing here? You said rear wheel bearing, right??
gdanaher is offline   Reply With Quote
Old 12-31-2010, 12:48 PM   #6 (permalink)
Gameroom cash: $202800
View Donald E. George's Photo Gallery
Try using a little heat to break the rust between the hub assembly flange and the mount. Use some anti-seize on the new bearing flange to avoid this condition again. I believe the four bolts torque to 59 ft.lbs.Burnish a small amount of anti-seize on the brake rotor to hub interface to make the rotor easy to remove. Work safe.
Donald E. George is online now   Reply With Quote
Old 01-01-2011, 07:52 PM   #7 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
+1 gdanaher.
It's probably just rust. Did you get a new o-ring with the bearing/hub assembly?
Use Autozone's free loaner tools, slide hammer (OEM27033) and hub puller flange (OEM27032).
http://www.autozone.com/autozone/ino...llersUniversal
Old 01-04-2011, 11:02 AM   #8 (permalink)
Originally Posted by JohnGD View Post
+1 gdanaher.
thanks for reminding me about the o-ring because I noticed my hub assembly did not include one and somewhere in the removal frustration I forgot I needed to go buy one.
First, to answer gdanaher, Yes it is the rear bearing and yes I am replacing the whole hub assembly. I already bought the new one.
I have found out that what probably happened is that the hub is seized on due to me driving it with the bad bearing which apparently has been generating alot of friction heat from being as wobbly as it is now.
I already tried the slide hammer and some PB blaster but it was to no avail. I bought a 4lb sledge as thats what the toyota service guy suggested since I dont have an air hammer and my rubber mallet didn't do anything. I haven't tried it yet, partly because I was worried about messing up the old hub without actually being able to remove it and then being stuck with an incapacitated car!
Any opinions/suggestions? What could I use to apply heat?
Old 01-04-2011, 02:42 PM   #9 (permalink)
Maven
gdanaher's Avatar
If you hit the outer portion of the bearing with the sledge it might have a potential for bending something behind it. Bad news. Use the sledge and a large cold chisel and wack the bearing assembly downwards at the seam. That should break it loose and avoid bending any other parts.
Old 01-04-2011, 07:09 PM   #10 (permalink)
If that's the case that's some rust!
Yeah, I wouldn't use a sledge hammer because you might bend something the wrong way. Double check all 4 bolts are removed and if a 5 lb slide hammer won't do it, I'm not sure how a 4 lb is going to do it properly.
See if you can break the rust seal first. Then the slide hammer/puller should do it.
Old 01-04-2011, 08:01 PM   #11 (permalink)
Maven
gdanaher's Avatar
Have you soaked this thing with Liquid Wrench?? Use the whole bottle!
