remote start w/ oem remote - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2011, 03:08 PM   #1 (permalink)
View hiemmer's Photo Gallery
I got a coolstart rs-4 remote starter for my 2002 camry xle. I have everything wired and working except that I want to use the factory keypad. This requires me to connect to a wire that grounds when the lock button is pressed on the keypad. If someone could help it would be greatly appreciated.
hiemmer is offline   Reply With Quote
Old 01-04-2011, 03:20 PM   #2 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
^I may be wrong but I think, as far as I know, the only way to work a remote start with the factory remote is to use Toyota's remote start system.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
The Following User Says Thank You to arabianobsession For This Useful Post:
hiemmer (01-06-2011)
Old 01-04-2011, 03:43 PM   #3 (permalink)
This remote start will work as long as I find a wire that grounds when I press the lock button on my keypad. It works by activating after three lock pulses. I have tested the remote start by touching the wire to a ground three times and it started. If I can find the wire I should be good. It may also require a relay but I'm not sure.
Old 01-04-2011, 03:44 PM   #4 (permalink)
Need For Speed
Alright, well, learned something new today, lol.
Old 01-05-2011, 06:08 AM   #5 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
The unlock wire for the doors is usually blue or green on Toyotas. Check the rubber boot running from the door into the car.
'07 Honda Ruckus Big Bore
The Following User Says Thank You to LynchburgCSI For This Useful Post:
Old 01-06-2011, 02:14 PM   #6 (permalink)
OK, figured it out today. It was the blue/red wire in the 13 pin connector at the driver's side kickpanel. Because the remote start requires 3 negative pulses and the ecm doesn't send the signal if the doors are already locked, I have to press lock unlock lock (each lock sends a double pulse). I posted this just incase someone else needs this info.
Thanks to everyone for there help!
Old 01-06-2011, 02:42 PM   #7 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
If I would've known about this, I would have told you not to even install it. It's best to get standalone unit.
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
