Front License Plate on 07 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2011, 07:58 PM   #1 (permalink)
View mppsu2003's Photo Gallery
I moved to NJ, which requires a front plate. I saw two small dimples on the front bumper. Is the best way to put a plate on there to drill through those dimples? Is there any other way?
mppsu2003 is offline   Reply With Quote
Old 01-05-2011, 08:45 PM   #2 (permalink)
'11 Camry SE
exclusive's Avatar
Gameroom cash: $305680
View exclusive's Photo Gallery
Option 1: Drill holes
Option 2: Buy a relocator bracket, drill holes in inconspicuous area in the under side of the bumper
Option 3: Zip tie to lower grill
2011 Camry SE
|| Click my car below to see my thread ||
exclusive is offline   Reply With Quote
Old 01-05-2011, 08:51 PM   #3 (permalink)
MJZ
Bulletime
MJZ's Avatar
Gameroom cash: $438105
View MJZ's Photo Gallery
You can also get a hideaway plate that mounts underneath your bumper and can be remote controlled.
If you want to put your plate on your bumper, don't use the dimples. Drill your own holes above it so it doesn't block your lower grille.
MJZ is offline   Reply With Quote
Old 01-05-2011, 08:59 PM   #4 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $612031
View Zembonez's Photo Gallery
Yes. Those dimples are the factory location. If you don't mind it there, the best thing is to drill in the place the bracket is made for. The bracket will cover the holes, so there's nothing to really worry about there. Like some others have said, a custom location is cool too.
Zembonez is offline   Reply With Quote
Old 01-06-2011, 12:18 PM   #5 (permalink)
Gameroom cash: $195750
View ImJustMe55's Photo Gallery
Here are some links to the hideaway/retractable license plate holders
Manual: http://cgi.ebay.com/ebaymotors/Musta...#ht_2544wt_939
Remote: http://cgi.ebay.com/ebaymotors/05-09...#ht_2225wt_939
ImJustMe55 is offline   Reply With Quote
Old 01-06-2011, 02:24 PM   #6 (permalink)
Gameroom cash: $304355
There is also a bracket sold by Toyota that screws in through the plate and goes through those same holes. It uses longer screws. It gives the car a more finished look. I ordered the bracket when I ordered my 07 Camry new in late 06. It was around $20 back then. The Toyota part number is(was) 52114-06030. If you order it, make sure it fits your year of the generation 6.
Mike
Mike Gerber is online now   Reply With Quote
Old 01-06-2011, 05:09 PM   #7 (permalink)
Toyota=$wellspent
View bass4me's Photo Gallery
2010 2011 changes
The part number does not have two sixes in it.
Here are two brackets that are used. The part number changes after Feb 2009. The part number ending in 30 has list price of 15.00 and the one ending in 80 is 65.82 OUCH!!!
BRACKET, FRONT BUMPER EXTENTION MOUNTING 52114-06030 2006.02-2009.02
BRACKET, FRONT BUMPER EXTENTION MOUNTING 52114-06080 2009.02-
Rob
bass4me is offline   Reply With Quote
Old 01-07-2011, 03:02 PM   #8 (permalink)
Rob
Rob,
Thanks for the correction. I went back and edited my previous post so there is no confusion in case someone refers to this thread in the future.
Mike
Old 01-08-2011, 01:39 PM   #9 (permalink)
View Aceventura9586's Photo Gallery
I went to Home Depot, bought a couple long bolts and clips and it's mounted through the grille under my bumper. Kept the bumper clean and looks better.
Put a strip of 3m foam adhesive on the back of the plate so it wouldn't scratch the paint. Like so..
Aceventura9586 is offline   Reply With Quote
