Door sensors not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2011, 11:29 PM   #1 (permalink)
DftMachine's Avatar
View DftMachine's Photo Gallery
Gen5 Door sensors not working
So when I open the door, everything happens the way it's supposed to: the door ajar light turns on in the dash and the dome light turns on.
But sometimes, the light in the dash turns off after a few seconds even though the door is open. Where are the sensors in the door?
Car is 05 LE
DftMachine is offline   Reply With Quote
Old 01-07-2011, 04:40 AM   #2 (permalink)
Asteroid's Avatar
View Asteroid's Photo Gallery
The door switch is on the bottom corner of the door opening, towards the centre of the car, facing outwards. You will need a torx bit to remove it.
04 ACV36R Camry Sportivo 4cyl manual
92 CE100 Corolla DX diesel (jdm import) *sold*
Asteroid is offline   Reply With Quote
Old 02-27-2011, 09:32 PM   #3 (permalink)
View XV40's Photo Gallery
bump. Unfortunately, I'm experiencing the same issues as DftMachine. I've gone ahead and unscrewed the door switch, but that's as much as I could do. I could not remove the switch assembly itself, nor the rubber covering to just wd40 it. Any thoughts on what I should do?
XV40 is offline   Reply With Quote
Old 03-05-2011, 02:28 AM   #4 (permalink)
Asteroid's Avatar
I had a similar problem with the driver's door switch, where it would intermittently fail to close the contact with the door open. As a result the auto off headlights would occasionally fail to work.
From memory the switch itself was cheap as, around AU$13? Just change it if in doubt.
