06 camry head problem
Hello! I have a 06 Camry with a 2.4 engine it has 91,000 miles.
When I started the car the other day it started missing along with a stinky smell along with a check engine light, checked the temp gage and it was ok checked oil level it was ok checked for water in the oil, no water in it. took it to a parts store for a check engine light check they said it was a piston one misfire and a random misfire. Drove it home and discovered the coolant tank empty so I filled it up.
next day when I started it, it misfired and white smoke was coming out the tail pipe. took it to a shop they took the plugs out and found coolant on the plugs and 3 cilinders, and said it needed a head job.
I don't understand it it only has 91k miles on it.
Could it be something ealse??
