Power Windows Won't Roll Down and Other Headaches
Greetings,
I have a few questions. I hope someone can help out. I have a 2007 Camry SE V-6. It was involved in a front left collision. I picked it up today from a toyota collision shop. On my way home, the power windows worked. When I parked the car and got back in it a few hours later, the windows did not work. I moved the gear shift, took the key out, pressed/depressed the window lock button. No luck. Drove the car home attempting to roll down the windows the entire trip -no luck. When I got home, I turned the car off, then turned switch to on but not running, and the windows rolled down. Any ideas? Also, during my drive home the car was sluggish. I did not notice this when I picked it up earlier from body shop but then again, I was traveling in heavy traffic.
I was told by a Toyota technician that if you disconnect the battery, it will reset any program updates to the transmission and there is a chance it would mess up the injectors because of carbon build up. Does anyone know if this is true? Any ideas on the sluggishness?
Thanks, Dude
