Adjusting Valve Clearances - 4 cyl Camry
I am rebuilding a 2004 Camry, 4 cylinder, 2.4, and the machine shop surfaced the head and did a valve job.
I am putting the motor back together now. I checked the valve clearances and the intake is suppose to be .008 to .011, and mine are:
.007/.010 .009/.009 .011/.011 .009/.009
On the exhaust, the specified range is .012 to .016. Mine are
.008/.009 .009/.009 .011/.011 .009/.009
I assume I need to get the cleanances with the range. Seeing that mine are on the tight side, I assume the only way to get the correct clearance is to get new lifters? If it is, should I shoot for being more towards the tight side to start out?
