Engine Block Heater - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2011, 10:51 PM   #1 (permalink)
View cheezpuff's Photo Gallery
Gen6 Engine Block Heater
TN,
I own a 2010 V6 Camry, and the car spends most nights outside in the winter. With the increasingly cold nights and mornings I was looking at purchasing and installing an engine block heater. Anyone have a DIY and part number for the kit?
Thanks.
cheezpuff is offline   Reply With Quote
Old 02-05-2011, 11:33 PM   #2 (permalink)
20 years of modding cars!
REMSSEV6's Avatar
View REMSSEV6's Photo Gallery
I personally don't see the need for it, but its your car...just use a high quality oil(preferably a synthetic) which in the manual it doesn't call for, but I don't think it will hurt anything. Synthetic oil has a better flow rate in cold weather and a higher heat tolerance than conventional oil.
REMSSEV6 is offline   Reply With Quote
Old 02-06-2011, 10:37 AM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
http://www.trdparts4u.com/scripts/pr...dproduct=-5127
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 02-06-2011, 10:43 AM   #4 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
Gameroom cash: $530410
View BlackCam09's Photo Gallery
i don't see a need for it, and i never knew such a thing existed. lol
Pioneer 7" AVH-P4200DVD|CDT Audio 6.5" CL-62Pro Comps|Alpine SPR-69C 6x9s |09 RD Alpha 15" in 2.75ft^3 @34hz |Sundown Audio SAZ1500D|Kicker ZX250.2|UR Strut Bar|H&R Springs|EE LED Tails|18" Konig Crosshair|RX330-TSX-R Clear lens Retrofit|Megan Catback|RKS Kit|UR 19mm RSB|BC Racing Coils
BlackCam09 is offline   Reply With Quote
Old 02-06-2011, 11:06 AM   #5 (permalink)
I used one similar to this hooked up to the heater hoses of my old MB diesel when I lived in Maine. Leave the heat on and my car was toasty warm and I never had to scrape snow or ice off the windshield. I attached it with separate hoses removed it in spring. Less stress on battery and the car started even when -30F.
Old 02-06-2011, 11:28 AM   #6 (permalink)
View Axxis8203's Photo Gallery
unless it's regularly significantly below 0 where the vehicle spends it's nights, then a good 0w-20 or 0w-30 will suffice just fine and provide significantly better cold start flow versus dino oil. Mobil 1 can be found quite easily in those flavors at WallyWorld.
as with any oil, the viscosity range will shorten as it ages and shears in the engine. So change it out just before the weather gets cold to assure you get the full benefits of the zero weight on cold starts.
I run 0w-30 in my 2gr-fe with yearly oil changes before winter.
Wise Men STILL seek Him!
Axxis8203 is offline   Reply With Quote
Old 02-07-2011, 11:48 AM   #7 (permalink)
I like getting into a warm car on a cold day.
Old 02-08-2011, 12:50 AM   #8 (permalink)
View Aceventura9586's Photo Gallery
Remote start.Nuf said
Aceventura9586 is offline   Reply With Quote
Old 02-08-2011, 10:05 AM   #9 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
^Block heater will warm it without the need to waste gas.
Here in Wisconsin it is currently -15. And will be the rest of the week. Personally, my car sits outside at night, and is a PITA to warm up or even run halfway decent when it's so cold. My last 3 cars have had block heaters from the factory, and they were lifesavers!!!
However, I'm moving to SC in the fall, so I'm now too lazy to install a block heater in the 11 SE.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 02-08-2011, 10:51 PM   #10 (permalink)
LOV
268 HP OWNER
LOV's Avatar
View LOV's Photo Gallery
Its -32F here and we have to use not only bock heater (factory installed) but battery warmer as well.
2007 Camry SE V6 , MGM
LOV is offline   Reply With Quote
Old 02-10-2011, 01:49 PM   #11 (permalink)
Need For Speed
Battery warmer? Interesting. We don't even sell them here...
Old 02-10-2011, 02:27 PM   #12 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Used them in Montana fifty years ago.........and dipstick heaters.
Old 02-10-2011, 02:59 PM   #13 (permalink)
View Thunnda's Photo Gallery
Originally Posted by LOV View Post
Its -32F here
Goodness! And I cry about how cold +32 degrees is here in SC!
White
SE V6
Thunnda is offline   Reply With Quote
Old 02-10-2011, 05:04 PM   #14 (permalink)
Need For Speed
Dipstick heaters? Is that like...blinker fluid or something? lol
Old 02-10-2011, 05:23 PM   #15 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $456050
View Luna2's Photo Gallery
It warms the oil....
Just like the heater pads (which I prefer) that I used on the oil pan and on the transmission pan in addition to the block heater, a battery heater and a trickle charger, then use full synthetic oil. All this for easy starts and smoother shifts when it is -15F to -50F that I encountered while I lived in Fairbanks, Alaska.
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is offline   Reply With Quote
Tags
block heater, camry, engine heater, heater
