2009 Camry gas gauge question` - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-04-2011, 06:50 PM   #1 (permalink)
View jshoe's Photo Gallery
I have a 2009 Camry. The gas gauge is stock. I have a simple question. When you turn the car off does the gas gauge go to empty or stay at the current position? Could you check? Mine seems to be sticking at positions. I just want to see whats normal. Thanks
jshoe is offline   Reply With Quote
Old 02-04-2011, 07:13 PM   #2 (permalink)
09 Camry SE V6
StealthTRD's Avatar
Gameroom cash: $203125
View StealthTRD's Photo Gallery
it stays there for a bit and then it goes down to empty till you start your car again and will show you how much gas you have or when you put it on..ON...
2009 Camry SE V6
70% Tint Front, 15% tint rear, K&N drop-in, 6k HID, tower bar, H&R springs
2011 Tacoma V6 TRD sport 2wd
StealthTRD is offline   Reply With Quote
Old 02-04-2011, 07:15 PM   #3 (permalink)
See mine stays at the gas level. The dealer said that is normal. But it never did that before. To me it's just a sign that failure is coming to it.
Old 02-04-2011, 07:21 PM   #4 (permalink)
09 Camry SE V6
StealthTRD's Avatar
so it still stays at the position when you come back to it the next morning?
2009 Camry SE V6
Old 02-04-2011, 07:23 PM   #5 (permalink)
yes, but on some days i go out to the car it will go to E. It's intermittent but most of the time now stays where it was. So it should go down to empty with the key out of the ignition?
Old 02-04-2011, 08:41 PM   #6 (permalink)
TN Master of Solder
View jonez's Photo Gallery
When you turn the key in the ignition it should re-level the gauges.
2009 Camry SE|Metallic Grey|Ashe Leather
All Interior LEDs | Load Resistors | LED Dual Color Turn Signals |Smoked LED Tail Lights | Cree 3W LED Reverse Lights | Rear V-Star Turn Signals | 4300K HID | Blackened Headlights | Black Cluster w/ Red/Blue Gauge & Green Needles | Yellow Fogs | 35% Tint
jonez is offline   Reply With Quote
Old 02-05-2011, 08:49 AM   #7 (permalink)
It doesn't... The gas gauge usually doesnt go to empty with the car turned off or anywhere near empty.... It stays where it was. Some morning I go out and it will be at Empty, but on most I go outside and it is wherever it was.
Old 02-05-2011, 09:06 AM   #8 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Well I sure wouldn't lose any sleep over it.......
Old 02-05-2011, 09:26 AM   #9 (permalink)
TN Master of Solder
When the gas gauge is left in the same place the next morning and you turn your car on, does the gauge move at all or just stay where it is?
There are gears in every one of the needles (i've taken them apart on a spare set) so gravity itself isn't going to pull the needle down, therefor it's NOT normal. The controller has to actually move them down to the zero position, the same as the temperature gauge goes to zero.
I'm sure Toyota will not do anything unless it reports the incorrect amount of gas WHEN you have the car running.
Old 02-05-2011, 09:44 AM   #10 (permalink)
Gameroom cash: $169021
View Dave-o's Photo Gallery
what about your coolant gauge? does that drop? lol
Dave-o is offline   Reply With Quote
Old 02-06-2011, 09:51 AM   #11 (permalink)
Jonez, Everything goes to zero but the gas. It used to. I have 1,000 miles left in my warranty and would like to get it fixed because to me it seems to be the early onset of a problem.
