What is the cause of this?! (oil leak) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2011, 06:25 PM   #1 (permalink)
KoG506's Avatar
View KoG506's Photo Gallery
This is my 2000 avalon, I know it doesnt belong in the camry section (its one of the most active section), i just need to know what is going on with my engine. I just notice it 30 mins ago. i love this car and i want to know what goin on with it so i can fix it ASAP. Please help me! Thank you very much!
I have pictures and currently uploading a video about 39 mins to go.
Basic details:
2000 Avalon
128+K mileage
KoG506 is offline   Reply With Quote
Old 02-07-2011, 06:47 PM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352560
View gdanaher's Photo Gallery
From the pictures I can't tell what you are talking about, but perhaps the valve cover is loose or the gasket is shot. See if the whole thing can be torqued down just a little. The stuff on your finger looks more like grease than oil, so if it is leaking, it isn't leaking very much.
gdanaher is offline   Reply With Quote
Old 02-07-2011, 06:49 PM   #3 (permalink)
Avy
Gameroom cash: $819455
View pmesfun's Photo Gallery
DO NOT over tighten the bolts, they will bottom out and shear off. Weird design. You need to remove the plastic cover and replace the valve cover gasket and spark plug tube seals. Common problem on the 1mz.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 02-07-2011, 06:51 PM   #4 (permalink)
KoG506's Avatar
i believe the leak is between the head and block
Old 02-07-2011, 06:54 PM   #5 (permalink)
KoG506's Avatar
so your 100% sure its the valve cover gasket?
is it a hard task to replace it?
Old 02-07-2011, 07:04 PM   #6 (permalink)
Avy
Yup, if you want, remove the plastic covered and take a pic. Makes it easier to determine if its leaking.
Its fairly easy to do, IIRC, its about 10 bolts and 2 nuts holding a harness cover to the valve cover. The upper radiator hose needs to be removed, so make sure you have Toyota Long Life Coolant.
You will need a torque wrench and basic tools.
Felpro has a gasket kit for both the front and rear valve cover with spark plug tube seals. Check if the rear valve cover gasket is leaking also, as it tends to leak first.
Felpro Valve Cover Gasket Kit:
http://www.autozone.com/autozone/par...78_11524_59213
99 Avalon XLS-149k
99 Lexus LS400-88k
The Following User Says Thank You to pmesfun For This Useful Post:
KoG506 (02-07-2011)
Old 02-07-2011, 07:07 PM   #7 (permalink)
KoG506's Avatar
Here is the video with the cover on. and there is a rattling noise do you know what is the cause? The Rattling noise is NOT from the plastic cover. I took the cover off before and rev engine same way and it made same noise. It happens around 2100 - 2400 RPM.
Ill go take more pics of it with the cover off.
Old 02-07-2011, 07:18 PM   #8 (permalink)
Avy
That's definitely the valve cover gasket leaking. Check the rear one also, but when the engine is COLD.
As for the noise, it sound like the timing belt is rapidly slapping the timing cover.
When was the timing belt replaced, and if so was the tensioner replaced also?
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 02-07-2011, 07:24 PM   #9 (permalink)
KoG506's Avatar
The yellow sticker in the video says around 88K mileage. the previous owner did not say if it has been replaced (the tensioner). but he did have documentation of the timing belt replacement. ill look at it too. but ill go take pics of the cover off and remove the cover of the timing belt to see anything interesting.
Old 02-07-2011, 08:10 PM   #10 (permalink)
KoG506's Avatar
More pic:
This one, the bottom screw is oily. it came off of the timing belt cover. located bottom front near alternator.
Old 02-07-2011, 08:14 PM   #11 (permalink)
Avy
Leaking for sure. Replace the gasket and tube seals.
As for the tapping noise, check the alternator/ac and ps belt and make sure they're tight. If they are, its most likely your tb and tensioner.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 02-07-2011, 08:36 PM   #12 (permalink)
KoG506's Avatar
Thanks for your help! when do you recommend changing the gasket?
is it ok to drive till spring time?
Old 02-07-2011, 09:49 PM   #13 (permalink)
Maven
gdanaher's Avatar
It didn't look like it is actually dripping oil--just a little wet on the edge. Might be a function of the winter temps making things hard and contract a little. I'd check it weekly and let it go until things thaw a little.
Old 02-10-2011, 12:09 AM   #14 (permalink)
Avy
Yeah I wouldn't worry about it for now, take care of it when it gets warmer.
Although you have a heavy leak around the pcv valve. Looks like it needs replacement and maybe the pcv valve grommet too.
I see the rear valve cover gasket is leaking at the top, but check the rear. The way the engine is positioned, there is a constant oil pool and the back of the valve cover. So check that when the engine is COLD.
99 Avalon XLS-149k
99 Lexus LS400-88k
