Very dim headlights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-08-2011, 06:45 AM   #1 (permalink)
View KLenart's Photo Gallery
Gen6 Very dim headlights
I did a lot of searching on this topic, but it doesn't seem like it's a common issue. I just purchased a 2007 SE V6 but the headlights are very very dim. I thought it was the bulbs so I replaced them. Still the same. The lens itself isn't new, but it's not bad. When I turn the lights on and take the bulb out, it's bright and normal. I'm guessing it's something with the halogen or the interior of the socket? Should I take the headlights off and clean the inside of the projectors? Not familiar with this yet. Any help is appreciated.
Thanks
KLenart is offline   Reply With Quote
Old 02-08-2011, 10:01 AM   #2 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $821521
iTrader Score: 16 reviews
View GT-R's Photo Gallery
Do you have a pic of it shining to a wall? Projector headlights look dimmer when you look at it from an angle.
GT-R is offline   Reply With Quote
Old 02-08-2011, 01:52 PM   #3 (permalink)
I don't have a pic, but they're dim. At night I can't see in front of me. Previous owner must have been messing around with them or something.
Old 02-08-2011, 02:03 PM   #4 (permalink)
270hp = Happy Foot
Gameroom cash: $396245
View aznlunatic206's Photo Gallery
please try to take a pic and post it. In reality you should be able to drive at night without headlights since you have streets light everywhere (atleast where i live). So you mean like you cant see the beam of light infront of you? or like no street signs reflecting back at you?
2011 Camry SE V6 Fully Loaded w/o Navi
V-HIDS 5000k HID Kit Low Beam, 3000k Nokya Fogs
20% Aegis Tint, 50% Front Windshield
Tein Solara Springs on KYB GR2's
aznlunatic206 is offline   Reply With Quote
Old 02-08-2011, 02:13 PM   #5 (permalink)
TN Master of Solder
View jonez's Photo Gallery
He's from central CT, there aren't many street lights whenever i've gone to central CT
Do the wires going into the headlight sockets look like they've been messed with in any way?
Could you explain this statement a little more, maybe i'm being thick but I don't understand it. What bulb are you taking out? when you take this bulb out, the projector low-beam headlights are fine?
2009 Camry SE|Metallic Grey|Ashe Leather
All Interior LEDs | Load Resistors | LED Dual Color Turn Signals |Smoked LED Tail Lights | Cree 3W LED Reverse Lights | Rear V-Star Turn Signals | 4300K HID | Blackened Headlights | Black Cluster w/ Red/Blue Gauge & Green Needles | Yellow Fogs | 35% Tint
jonez is offline   Reply With Quote
Old 02-08-2011, 02:17 PM   #6 (permalink)
Gameroom cash: $118425
View Mag Grey Toy's Photo Gallery
yeah a picture would def help lol
once u get that we can see whats wrong
Mag Grey Toy is offline   Reply With Quote
Old 02-08-2011, 02:27 PM   #7 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Maybe the previous owner was trying to do a retro and failed.
Old 02-08-2011, 03:20 PM   #8 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
I had this issue in my 95 Mustang. It turned out, someone messed with the entire lens and re-installed it kinda crooked, so it was pointing towards the ground instead in front.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 02-08-2011, 03:24 PM   #9 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
Gameroom cash: $530410
View BlackCam09's Photo Gallery
Try examining the headlights by removing them, and look into the hole where the bulbs go to see how the inside looks and if anything is damaged. Maybe someone had a hidkit installed and it melted the inside bowls of the projectors, who knows.. Also are the headlights clear or are they hazel up?
Pioneer 7" AVH-P4200DVD|CDT Audio 6.5" CL-62Pro Comps|Alpine SPR-69C 6x9s |09 RD Alpha 15" in 2.75ft^3 @34hz |Sundown Audio SAZ1500D|Kicker ZX250.2|UR Strut Bar|H&R Springs|EE LED Tails|18" Konig Crosshair|RX330-TSX-R Clear lens Retrofit|Megan Catback|RKS Kit|UR 19mm RSB|BC Racing Coils
BlackCam09 is offline   Reply With Quote
Old 02-08-2011, 04:10 PM   #10 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
My guess is there is no problem to be found.....it's the OP owner.
Old 02-08-2011, 06:16 PM   #11 (permalink)
Might be SCRAPING soon...
Gameroom cash: $107550
View rtagn's Photo Gallery
I'm pretty sure he meant that he turned on his headlights while the H-11's were in the socket and removed them out of the socket while they were on to check the brightness. He says he sees a difference from when it was being projected and when he took it out.
In other words, it may be the projector, but don't clean the insides, its may ruin the projector. I would say its either the lens, or the bulb. If its the projector, it may be the lens projector that is dirty, that you can clean. If anything else it may be the projector reflectors are burnt which I doubt because he would have to be running high temp bulbs in there to burn the reflectors.
Those are my 2 cents.
2009 Camry LE
Barcelona Red
Mods: rx-afs Retrofit, Independent Fogs, Lumincs 2500k fogs and drl/highbeams, 35% tint all around, 5% strip on front windshield indash Nav
Want: Coils, wheels, LED tails
rtagn is offline   Reply With Quote
Old 02-09-2011, 03:07 PM   #12 (permalink)
Gameroom cash: $186285
View badbadtz560's Photo Gallery
goin w/ rtagn's - maybe someone used HIDs in'em and killed the chrome or high wattage halogens. can't tell anythign w/o some pics tho
badbadtz560 is offline   Reply With Quote
Old 02-12-2011, 08:17 AM   #13 (permalink)
Thanks everyone for your input. I'm almost 100% sure that somone had hids installed because the piece where the bulbs latches in and turns is burnt. So i'm guessing the inside of the halogens is melted or maybe just dirty? Can anything be done or am I looking at a used set of headlights?
Thanks
Old 02-12-2011, 09:22 AM   #14 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
Thanks
probably better off just purchasing a set of new/used headlights off ebay.
Old 02-12-2011, 09:59 AM   #15 (permalink)
Tech1984's Avatar
Gameroom cash: $254450
View Tech1984's Photo Gallery
I used to read here about doing the conversion over to HID's, and "you must remove the squirrel spotters"<?> , or you'll be blinding people.
So whatever that is, could this be his whole problem?
Bin wrenchin' on the Yota's since '84
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5
Cheers!
Tech1984 is online now   Reply With Quote
