Hello
I have a 2003 camry with the 2.4l 4 cylinder. The 3 rear head bolts striped out and head gasket leaking
so i pulled the head and used time-serts in the block. Now here is my problem. we put it back together and it ran for about 7-10 minutes. then started to knock. We pulled the head and all exhaust vales were bent.
I know we set the chain right (it is colored coded links). Manual said to time oil pump chain also. we did not do that but what does that have to do with the valves bending. I have done many timing belts and chains so i do not know were i went wrong or what to look for when i put it back together.
Red link on chain was at 3 oclock and the 2 yellow marks were at the marks on the 2 cams. Any help will be nice. Thanks
