Need help to adjust the gauge cluster needles - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-09-2011, 04:53 PM   #1 (permalink)
View shahabmusic's Photo Gallery
Hi I went through DIY on how to change gauge cluster LEDs to different colours. I opened the cluster and took out all the needles but I forgot to memorize where the were now I put them back in but they don't show the right and accurate amount:-( apparently temp gauge is fine because after 30minutes of drive it stays at the middle. I can sort out speeds needles using OBD2 to USB but I have no clue how to adjust the gas needle:-( my obd2 doesn't show the gas status.... is there any other way to find out how much gas is in the tank so I can adjust the needle appropriately.
shahabmusic is offline   Reply With Quote
Old 02-09-2011, 05:45 PM   #2 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
yeah, fill the tank!
once the tank is full, you should have a reference point to place the needle at the full mark.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 02-09-2011, 05:56 PM   #3 (permalink)
Lol Yea I thought that but I remeber whenever I filled up the tank, needle was staying eaither a bit higher that the full or a bit lower that the full point. And when I used to fill the tank right up few times and it showed way higher than full point.
I try my local dealer hopefully they can help me with that :-(
