Headlight problems!! help!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-12-2011, 07:43 PM   #1 (permalink)
View Dragonn615's Photo Gallery
Hi guys,Heres the thing long story short i bought cheap bulb and it burnt my oem headlight.so it burnt the hole where you input the bulbs.So i went and bought a ccfl headlights and took the oem ones and left it in my garage.I bought a hid kit with the ccfl headlights but once i installed it while driving i can barely see the lights.ive seen picture of you guys camry with the light so defined and intense mine i can barely see a few feet.Is not not leveled i turned it counterclock wise to lower it but still the same.Is it somthing wrong with the wires after the bulb burnt? or what?but either way i plan to begin a project as ive researched on here and found a few retro projects.should i buy the tsx projector?but is it simple the screws line up? http://www.theretrofitsource.com/pro...products_id=61
thanks guys. im driving with my highbeams and even though i bought halogen bulb and it still the same.
Dragonn615 is offline   Reply With Quote
Old 02-12-2011, 08:01 PM   #2 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
Gameroom cash: $530410
View BlackCam09's Photo Gallery
How did you burn your OEM headlights by buying cheap bulbs? Did you install them wrong or something? You should have just bought OEM headlights again. I heard those CCFL headlights have crappy output. As for the retro projects you are talking about it requires more then just lining up the screws. lol. It requires a little bit of time, knowledge, and research to do a retrofit...
Pioneer 7" AVH-P4200DVD|CDT Audio 6.5" CL-62Pro Comps|Alpine SPR-69C 6x9s |09 RD Alpha 15" in 2.75ft^3 @34hz |Sundown Audio SAZ1500D|Kicker ZX250.2|UR Strut Bar|H&R Springs|EE LED Tails|18" Konig Crosshair|RX330-TSX-R Clear lens Retrofit|Megan Catback|RKS Kit|UR 19mm RSB|BC Racing Coils
BlackCam09 is offline   Reply With Quote
Old 02-12-2011, 08:19 PM   #3 (permalink)
i bought cheap headlights and that time i was did not know anything and just randomly bought a pair of bulb and later i realized that they were 100 watt. and like i notice the light output sucked so i open the hood and it totaly burnt the ring so i pryed it off.
Old 02-12-2011, 09:04 PM   #4 (permalink)
ju
i cant upload the picture so i uploaded onto cardomain it the last picture.
http://www.cardomain.com/ride/383610...edan-4d/page-1
[IMG]file:///C:/Users/Huy/Desktop/IMG_0431.JPG[/IMG]
Old 02-12-2011, 09:15 PM   #5 (permalink)
Gameroom cash: $246200
View fatngs's Photo Gallery
i wouldnt be suprised if the wire harness for the low beams is toast..... u can try running the low beam HIDs with a relay kit..... it will draw the power from the battery instead of the fried headlight harness and you should get a bit more brightness
TSX projectors are good..... thats what i have retro'd in stock housings..... only issue with them is alotta times they have a slight flare issue on the right side but it's not extreme
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
fatngs is offline   Reply With Quote
Old 02-12-2011, 09:17 PM   #6 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
I love these tales...............
Old 02-12-2011, 11:07 PM   #7 (permalink)
so should i bring it to a mechanic and let them check out the wires to see if it toast?would it cost alot?
Old 02-12-2011, 11:11 PM   #8 (permalink)
Gameroom cash: $186285
View badbadtz560's Photo Gallery
I hope you saved your original headlights. buy some stock projectors off of someone from the forum. What you gotta do is use an oven to open up your headlights .. then u just screw the newly purchased stock projectors back in.
the stock projectors are somewhat separate from the headlight housing.. so hopefully your housings didn't get damaged as well
If u want an upgrade.. u can look at the HID projectors for mdx and solaras.. but good luck finding those If u can get'em they're pretty much screw-in and much better than stock camry projectors since they're made for HID (they use d2s bulbs I think)
Try taking a pic of those lights against the fence for us w/o the high beams
and btw.. aftermarket ccfl headlights are known for having crappy output.. you're better off putting an HID kit in your stock camry projectors
badbadtz560 is offline   Reply With Quote
Old 02-12-2011, 11:18 PM   #9 (permalink)
lol green was just messing around when i bought an hid kit he accidently sent green but i returned it.i still kept my oem headlights but still wondering what should i do because the tsx projectors cost 195 and the hidkit on xenondepot.com cost about the same i just dont know which should it do.?is and back to the other reply how would i connect the relay kit? either way im still losing 200 or how about take my oem headlight retro fit it with tsx and get a hid kit with a relay and sell the ccfl headlight?
Old 02-12-2011, 11:23 PM   #10 (permalink)
also can i replace the houseing because it burnt like the plastic part where you put the bulb into the headlight
Old 02-12-2011, 11:25 PM   #11 (permalink)
I thought u were already running 4300k hids in your lows. that means you have a ballast for both headlights already as well as h11 hid bulbs?
I'm under the impression that TSX projectors suck - I have no personal experience with them, but all the experts I trust (on HIDP) say that they're way overpriced for what they're capable of. I CAN tell u that a neighbor's tsx was completely out-shined by my rx330 crappy custom-shield tho.. but I do not know the age of their bulbs or anything.. we were just driving in the same direction.
If you already have a 4300k hid kit in your car, blowing another 200 bux on a second hid kit isn't gonan do you any good.
it'd help if u can post a pic of your burnt stuff too btw
Old 02-12-2011, 11:32 PM   #12 (permalink)
ye im already running an hid kit with 4300...but how would i connect the relay harness if it didnt come with the kit.?lol please dont bash on me i dont know much about lightings
Old 02-12-2011, 11:34 PM   #13 (permalink)
RX AFS Retrofit Progress(56K no no!)
take a look at pawel's thread and take note at how the projectors come out of the housing. Then tell me what's burnt and what isn't. If your projectors are the only thign that got cooked, they're you're in luck b/c u have a perfectly healthy housing.
this is all the info I can share w/ retros.. there are others that know a lot more - i'm sure they can chime in shortly
ease of camry installation:
Solara > MDX > mh1 > RX330
Mine are rx330 customshields + Mh1 for high beam. I use my fogs as drl/high beam as well.. so I have dual lows and dual highs if I want
or you can wait for the famous s2k-rs that aren't out yet... but u might see blizzard come out w/ diablo3 before u see s2k-rs
well.. take a pic of your ballast for me XD or link me to your kit. I'm betting they're 9006 connectors on'em. If it's the typical cheap chinese stuff, u take the wire that goes in to your ballasts and plug that in to the harness. then the harness has its own connector that plugs in to the ballast. You do this on the other side as well.. and then u have a red and black, which typically just hook up to the battery.
Old 02-12-2011, 11:47 PM   #14 (permalink)
would this work? http://cgi.ebay.com/ebaymotors/H11-H...Q5fAccessories
Old 02-12-2011, 11:49 PM   #15 (permalink)
depends how much work or how much money u want to spend... or how good you want those lights to be... since you have two housings already, I'd try a retrofit - sounds like u want really good lighting...
rx330s are cheaper than tsx but require work to get'em better. Once u modify the shields, they rival the $300+ s2000s which means they totally pwn the tsxs
mdx and solara HIDs are screw-ins. I've never bothered looking for them so I don't know cost
stock camry projectors are screw in of course.. and a lot of ppl put hid kits in those... I did that once...
mh1 are easy to install in to the high beams.. it requires some dremeling to make the hole better.. and then they're screw-in...
Looks like that relay harness will work. the blue one goes to your stock wire, the (1) and (2) go to the ballasts, and then the remaining two wires go to the battery. Or the black can go to another ground..
I have my doubts that it'll improve lighting, but it's certainly a good thing to use to protect your stock wires from getting damaged.
