Help with replacing a starter on a 03 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2011, 03:51 PM   #1 (permalink)
View bluetc06's Photo Gallery
I need help with a DIY starter replacement on my 03 Camry. Can anyone help?
bluetc06 is offline   Reply With Quote
Old 02-14-2011, 05:58 PM   #2 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
which engine?
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 02-15-2011, 07:26 PM   #3 (permalink)
4 cyl.
Old 02-16-2011, 07:48 AM   #4 (permalink)
The location of the starter is always at the mating area b/t the engine and the transmission.
removal: battery, air box
starter removal: two wires(1. connector 2. bolted 8-10mm), two bolts at the flange (14 or 17mm).
then swap it out with a new one. btw, in the future if you want to rebuild it, you will need to buy a kit that include one plunger and two contacts. That will repair your starter and save you a hundred bucks or two.
