transmission fluid level 2011 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2011, 08:08 PM   #1 (permalink)
View Cathair's Photo Gallery
I have a 2011 camry, I can not figure out how to check my transmission fluid. I don't see the dipstick under the hood anywhere. Please help me.
Cathair is offline   Reply With Quote
Old 02-14-2011, 08:33 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
No dipstick, sealed tranny, special procedures to check and change fluid.
Another repeat thread....same as the 6 speeds for the last FIVE years...
Old 02-14-2011, 08:35 PM   #3 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
they use world standard tranny fluid now and they last long time. you can't really check it but there's a 21mm-or-so cap to fill it and you can stick your finger inside and check
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 02-14-2011, 08:37 PM   #4 (permalink)
Avy
Gameroom cash: $819455
View pmesfun's Photo Gallery
My dad's Avalon has a trans. pan gasket leak. I need to replace the gasket, but I don't want to destroy the transmission by not doing the fill/drain procedure correctly.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 02-14-2011, 08:40 PM   #5 (permalink)
'07 XLE
Gen6
There is a TSB issued for that..........
Old 02-14-2011, 08:50 PM   #6 (permalink)
Avy
mind giving me the number or download link?
Thanks
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 02-14-2011, 09:09 PM   #7 (permalink)
'07 XLE
Gen6
TSB TC014-07, 8/11/07, Transaxle Fluid Level
T-SB-0129-08, 7/9/08, Insp. Temp Ranges
The Following User Says Thank You to njerald For This Useful Post:
pmesfun (02-14-2011)
Old 02-14-2011, 09:37 PM   #8 (permalink)
Avy
Those tsb showed 08 avalon, we have an 07, but thanks anyways.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 12-10-2011, 01:03 PM   #9 (permalink)
View Moutee's Photo Gallery
Could someone please provide a link or an explanation for how to change the fluid on a 2011 Camry LE I4? Thank you.
Moutee is offline   Reply With Quote
Old 12-10-2011, 01:39 PM   #10 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
go to the dealer. you would need a code reader or some type of device to read the fluid level.
Glenn8963 is offline   Reply With Quote
Old 12-10-2011, 01:58 PM   #11 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
The 08 has the Aisin U660E 6-speed, and the 07 has the U151E and a dipstick!
But both should have the felt filter replaced say 30-50K miles and the pan and magnets checked/wiped clean. Valvoline MaxLife ATF should work fine with these two transmissions.
As far as OP's '11 goes, with all newer transmissions the fluid is checked more like a manual transmission - with a fill plug (check plug) and drain plug and within a specific temp range.
Old 12-10-2011, 04:34 PM   #12 (permalink)
I have access to an Actron OBDII scanner. Can I use it to check the level without going to the dealer?
Old 12-11-2011, 12:51 AM   #13 (permalink)
Many of the above average scan tools can read domestic transmission temperatures but not imports even if they have temperature sensors. However with the U660E IIRC the "D" light will flash a certain way if you're in the proper temperature range for fluid changes. I don't know if any ever reads ATF level however.
Old 12-11-2011, 12:57 AM   #14 (permalink)
Avy
Yeah, I never got around to changing the fluid. My brother drives that car now and lives in another city. Maybe I'll change it next spring break. Although last time I checked, probably around 60k, the fluid was still bright red. I'll stick with Toyota WS, don't want to risk anything.
99 Avalon XLS-149k
99 Lexus LS400-88k
