hard to start camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-15-2011, 08:17 AM   #1 (permalink)
05 Camry SE
spanishfly714's Avatar
View spanishfly714's Photo Gallery
This is my 1st camry se with a 2.4 and i'm not sure if its normal? but everytime i start it. i have to hold the key for a few seconds for it to start? is this normal? most cars i have i turn the key and it starts right up? I changed the air filter and spark plugs but no change? anything else i should try?
spanishfly714 is offline   Reply With Quote
Old 02-15-2011, 10:22 AM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352560
View gdanaher's Photo Gallery
If you want an answer you need to provide more info. What year is it, how many miles???
gdanaher is offline   Reply With Quote
The Following User Says Thank You to gdanaher For This Useful Post:
spanishfly714 (02-15-2011)
Old 02-15-2011, 10:46 AM   #3 (permalink)
05 Camry SE
still learning...
My camry se is a 2005 2.4 auto with 98000 miles
Enjoying life
Old 02-15-2011, 11:59 AM   #4 (permalink)
Gameroom cash: $246200
View fatngs's Photo Gallery
i would test the battery & starter..... advance auto will do it for free
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
fatngs is offline   Reply With Quote
Old 02-15-2011, 12:06 PM   #5 (permalink)
05 Camry SE
I will have that tested was wondering about the timing? does this eng. have a timing belt or chain?
Enjoying life
Old 02-15-2011, 12:08 PM   #6 (permalink)
chain
The Following User Says Thank You to fatngs For This Useful Post:
Old 02-15-2011, 12:58 PM   #7 (permalink)
View NegativeTen's Photo Gallery
You'll need to be a bit more specific on the how exactly it's "difficult" to start. Does the engine crank healthily while you have the key turned, and then a few seconds later it fires right up? Or is the cranking sluggish and uneven, and it barely even wants to start?
If it's the former, I'd look into something internal to the engine (plugs, wires, coils, MAF, fuel pump, or even timing like you suggested). If the latter, then most likely the issue is your battery or starter.
Hope this helps!
NegativeTen is offline   Reply With Quote
Old 02-15-2011, 01:00 PM   #8 (permalink)
Maven
gdanaher's Avatar
Assuming the battery checks ok and the starter spins quickly as it should, the next step would be to pour a couple cans of injector cleaner in the gas, and then pull the air intake apart ahead of the throttle butterfly and zap it with some carb cleaner. Try to clean the crud out from around the throttle area. Lots of folks around here will swear by SeaFoam and I won't argue with them. Check any vacuum lines for a break or leak. These last better than they used to, but still sometimes they fail.
Old 02-15-2011, 01:32 PM   #9 (permalink)
05 Camry SE
Hope this helps!
the engine crank healthly. just takes a few seconds to crank? I changed plugs, air filter and put a can of seafoam in the tank which i'm still running.
Enjoying life
Old 02-15-2011, 01:34 PM   #10 (permalink)
05 Camry SE
will try carb cleaner this weekend... : )
Enjoying life
Old 02-15-2011, 02:14 PM   #11 (permalink)
Be sure to get non-chlorinated carb cleaner. If the chlorinated stuff gets on the wire sensors of your MAF you can run into more trouble than you've bargained for. Better yet, get a can of MAF Cleaner (I think CRC makes it) instead. Even so, avoid spraying directly on the MAF wires.
If it's cranking fine then your problem then your problem is only one of three root causes: spark, fuel, or air. Those three things are the essential components to ignition, and any one can give you exactly the problem you're having. Either you're getting too much or not enough fuel (fuel pressure regulator, or fuel pump), too much or not enough air (cracked vacuum, leaky manifold, deposits in the throttle body), or a bad spark (weak, or out of time).
Make sure your plugs are properly gapped if using single-electrodes, make sure wires are all snug, check for vacuum leaks. If all of that fails and you're still at a loss, move onto checking the fuel pressure and more serious things like compression.. but it's probably nothing that serious.
The Following User Says Thank You to NegativeTen For This Useful Post:
Old 02-15-2011, 04:56 PM   #12 (permalink)
2012 Camry SE Mag Grey
SilverBullet's Avatar
Gameroom cash: $109600
View SilverBullet's Photo Gallery
Gen5
just started my 03 with almost 59,000 miles (yes, low miles, i know) and it takes longer than other cars but i think it might just be normal
Lunar Mist 2003 Camry LE 2AZ-FE; 65,400 miles
OEM Spoiler | painted engine cover | plasti-dipped emblems | painted fuse box cover | carbon HVAC controls | blacked out chrome accents | window tint 35% front 20% rear | TRD performance air filter | gen 5.5 SE grille
SilverBullet is offline   Reply With Quote
Old 02-15-2011, 06:49 PM   #13 (permalink)
05 Camry SE
I sure hope it's nothing serious... Thanks for the info.. i got a lot to try.
Enjoying life
Old 02-15-2011, 07:37 PM   #14 (permalink)
Gameroom cash: $137274
View johnfrisco's Photo Gallery
Get a new battery. Problem solved?
johnfrisco is offline   Reply With Quote
Old 02-16-2011, 09:39 AM   #15 (permalink)
05 Camry SE
I wish it was that easy.. it turns over good?? just takes a few times for it to start??
Enjoying life
