2010 Camry Wheels - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-16-2011, 08:37 AM   #1 (permalink)
EKG
View EKG's Photo Gallery
2010 Camry Wheels
Hello Fam!
I would like to get rid of the ugly ass steel wheels and replace them with the 2002-2006 ALY69416 Camry Silver Painted Wheel.
My steel wheels are the EXACT size as the Silver Painted Wheel..16x6.5 along with the lug and bolt pattern being the same size as well.
I've done the research and it seems to me that I should not have any issues replacing the wheels but I need a second opinion.
Will in fact I have any issues replacing my steel wheels with the silver painted?
Help me out!
http://www.hubcaphaven.com/mm5/merch...egory_Code=491
EKG is offline   Reply With Quote
Old 02-16-2011, 09:14 AM   #2 (permalink)
2009 Camry SE I4 MGM
glenn14's Avatar
Gameroom cash: $339325
View glenn14's Photo Gallery
EKG..
I don't see any problem at all..those look like the Gen 5 SE version. Plus you said they are the same bolt pattern and 16x6.5 . I would go for them. Unless you decided to go aftermarket. Its a direct swap !!!
Glenn
2009 Camry SE MODS:
Blacked Out Headlights with MDX D2S Retrofit,TSX-R Clear Lens, 85122+D2S Bulbs, G2 Red Painted Calipers, W.T.Floor Liners, Rosen Navi. GEN6.5 Chrome Wheels, XD Digital 35 watt ballasts, H11 Wire Harness, Megan fstb.
glenn14 is offline   Reply With Quote
Old 02-16-2011, 06:06 PM   #3 (permalink)
View Robert1820's Photo Gallery
Those wheels would look good on your car. Find out about the center caps and lugnuts before ordering. The little stuff can really add up, especially if those wheels require Toyota shank type lugnuts. Use a wire brush to clean any rust or corrosion from the hubs and lightly coat them with grease or (better) anti-seize.
Robert1820 is offline   Reply With Quote
Old 02-17-2011, 07:05 PM   #4 (permalink)
'11 Camry
View JasonA's Photo Gallery
I changed the steel wheels on my '11 Camry to wheels from a 06-09 Avalon. They were new take-offs, 16x6.5, same size as the Cam's steel wheels. You will likely need new lug nuts; your steel wheels use a tapered seat lug nut and most Toyota alloy wheels use a shanked seat lug nut. I would recommend buying a set of OEM lug nuts (either new or used). I first tried a non-OEM set of lug nuts for my new alloy wheels, but they started to rust after a few months on the corners. OEM is the way to go. I imagine your tire pressure sensors should swap across no problem.
JasonA is offline   Reply With Quote
Old 02-17-2011, 07:11 PM   #5 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
Also, the factory alloy wheels are extremely expensive and I hope you are getting them slightly used, otherwise, expect to pay $200 a rim at minimum. It would be cheaper to go aftermarket at that rate
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 02-17-2011, 07:14 PM   #6 (permalink)
Toyota/Scion Salesperson
Gameroom cash: $101652
View 09CamrySE3R3's Photo Gallery
QFT!!!! If you are willing to shell out $200/rim might I suggest Tirerack.com and you will have a plethora of options!!!
http://www.toyotanation.com/forum/signaturepics/sigpic178808_1.gif
09CamrySE3R3 is offline   Reply With Quote
Old 02-18-2011, 09:25 AM   #7 (permalink)
glenn14's Avatar
The OP provided a link and the wheels are 139.99 each with free shipping.
Glenn
2009 Camry SE MODS:
Old 02-18-2011, 10:14 AM   #8 (permalink)
Need For Speed
^Stupid work computer doesn't let me look at links 99% of the time.
$139.99 isn't bad, but at that price, there are aftermarket ones out there that look better, IMO
Old 02-18-2011, 11:02 AM   #9 (permalink)
glenn14's Avatar
I hear you..when I worked for HP, they would block sites so you could not
surf the web while working Oh and they offer all 4 wheels for $529 BTW nice 2011 SE !!!
Glenn
2009 Camry SE MODS:
Old 02-18-2011, 11:23 AM   #10 (permalink)
Need For Speed
Yeah, it's funny how most are blocked but ones like TN here are not
Thank you! I'm hoping to maybe put some rims on and tinit the windows this summer.
Old 02-21-2011, 05:09 PM   #11 (permalink)
EKG
I really appreciate everyone's input. I'm gonna go for it. Matter fact I located another aftermarket place that I can get the same wheels and save about $40. It's not much but every penny counts these days.
thank you all again.
Old 02-21-2011, 07:19 PM   #12 (permalink)
Need For Speed
Nice! Any little bit helps
Old 02-22-2011, 01:33 AM   #13 (permalink)
View Aceventura9586's Photo Gallery
I know someone who's interested in getting rid of his TRD 18's **ahem, cough cough**
Aceventura9586 is offline   Reply With Quote
Old 02-22-2011, 10:09 AM   #14 (permalink)
Need For Speed
^Who????? I DO WANT!
