Weathertech sunroof deflector - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-16-2011, 12:58 PM   #1 (permalink)
View newport3158's Photo Gallery
I have a 2011 Camry XLE, I purchased a weathertech sunroof deflector. I am a bit confused on how to actually install it. It seems simple, but I am confused where exactly these clips fit onto the sunroof?
The instructions are given here:
http://www.weathertech.com/pdf/instructions/srd-10.pdf
Any ideas, help, pictures would be greatly appreciated!
Thanks!
newport3158 is offline   Reply With Quote
Old 02-16-2011, 01:14 PM   #2 (permalink)
View ricker1's Photo Gallery
I recently installed one of these on my '08 Highlander, but the clips should work the same. It REALLY helps to have a helper on the inside. Just slip the clip under the lip of the roof and press down until you can start the screw...it may seem like the screw is too short, but it should start if you compress the plastic somewhat. The helper will be aligning the clip for you. Be sure you have positioned the deflector properly before attaching the clips.
ricker1 is offline   Reply With Quote
Old 02-16-2011, 01:36 PM   #3 (permalink)
Thanks,
I think i've figured it out it doesn't look like something I'm going to be able to do alone. And the screws seem awfully short, but maybe with another person it would be easier to get them in the holes. Thanks for your post, guess I'll just have to continue to wait till i get an extra set of hands!
Tags
deflector, install, sunroof, weathertech
