installing sub woofers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2011, 11:38 PM   #1 (permalink)
View jchin92's Photo Gallery
hi i want to set up subs in my Camry le 2008 and keep factory HU. i have the MTX Re-Q 3 channel that im going to use as a converter. i want to set it up in trunk but dont know how to supply it power. one forum said that it can be done by just putting it with the amps power terminal because the power wire for the re-q has to be constant. i want to confirm if i can do this or is it safe? i know i can run a wire all the back but that seems like doing too much.
jchin92 is offline   Reply With Quote
Old 02-20-2011, 03:23 PM   #2 (permalink)
270hp = Happy Foot
Gameroom cash: $396245
View aznlunatic206's Photo Gallery
yes you can just attach it to the terminals with the amp, nothing will happen. the unit should turn on and off depending if it senses a signal from the speakers. you'll be fine.
2011 Camry SE V6 Fully Loaded w/o Navi
V-HIDS 5000k HID Kit Low Beam, 3000k Nokya Fogs
20% Aegis Tint, 50% Front Windshield
Tein Solara Springs on KYB GR2's
aznlunatic206 is offline   Reply With Quote
The Following User Says Thank You to aznlunatic206 For This Useful Post:
jchin92 (02-20-2011)
Old 02-20-2011, 04:13 PM   #3 (permalink)
coool thanks
Old 02-22-2011, 09:06 PM   #4 (permalink)
sorry but another question how is the fuse wired up, and the 12v switch on im still very confused now...
