Rear sway bar options for 2011 SE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2011, 12:21 AM   #1 (permalink)
View RandyL's Photo Gallery
I've been searching around here and can't seem to locate any options for a larger rear anti-way bar for my new 2011 SE. TRD doesn't seem to offer one for the gen 6 Camry, only Gen 5 thru 2006. Can anyone point me to some sources?
RandyL is offline   Reply With Quote
Old 02-20-2011, 12:27 AM   #2 (permalink)
Woodzy88's Avatar
View Woodzy88's Photo Gallery
Canada
Ultra Racing is the only one that I know of that makes one for the Gen 6. I have the 23mm but they also have a 19mm option. Theres are completly solid where ours is 16mm and hollow.
Hope this helps.
07 Barcelona Red(3R3)Camry SE,2AZ-FE(I4)E351(5M) Smoked LED Tails,Black Halo Headlights,Shaved tail,Black Emblems,TRD TC Short Throw Shifter,TRD Dual Exhaust,K&N Intake,DC Header,UR Front Member Brace,UR Front Tower Bar,UR 23mm Rear Anti-roll Bar,UR Rear Member Brace's
Woodzy88 is offline   Reply With Quote
Old 02-20-2011, 12:37 AM   #3 (permalink)
Aha, thanks. I found it on their web site here, but apparently they don't sell direct. Who sells them, and does anyone know of any other options?
Old 02-20-2011, 01:36 AM   #4 (permalink)
i <3 Toyota
HiTek21's Avatar
Gameroom cash: $137939
View HiTek21's Photo Gallery
http://www.nextgentuning.com/Home.html
Check this site, i got my ultra racing front strut tower bar.
you might need to look under 2010 camry to get the 23mm swaybar because it doesn't show up under the 2011
2007 Speedway Blue Tacoma X-Runner 1GR-FE - URD Exhaust, URD Y-Pipe, TRD CAI, TRD Short Shifter, SS swaybar kit, TTC Traction bars, TL Projector retrofit, and more
2010 Magnetic Gray Metallic Camry SE V6 2GR-FE - TRD Dual Catback Exhaust, JL Stealthbox, Alpine PDX-M6, UR Strut Bar
HiTek21 is offline   Reply With Quote
Old 02-20-2011, 08:05 AM   #5 (permalink)
Gameroom cash: $169021
View Dave-o's Photo Gallery
the description on nextgentuning says 07-11 for their sway bars
put in your car info on the left ('11 camry) and then click last (last page), it'll show the UR products available for your car
the 19mm sway bar is available on the website for the '11 but doesn't show the 23 oddly.. but if you want that just put in 07-10 camry and it'll show up
Dave-o is offline   Reply With Quote
Old 02-20-2011, 10:36 AM   #6 (permalink)
Thanks guys, I'm on it...
1. Anyone done business with NextGenTuning.com?
2. Anyone installed one of the Ultra Racing 23mm bars that can relay their experience?
If the stock bar is 16mm I'm thinking that 19mm wouldn't be that much of a change. My new Camry seems to push (understeer) a fair amount as expected, I'm thinking the 23mm is the way to go to remedy this.
Thoughts?
Old 02-20-2011, 11:51 AM   #7 (permalink)
everyone here that's installed a new sway bar loved the difference
I purchased my 19mm from Evan @ nextgentuning and personally think it made the ride much better
Old 02-20-2011, 02:48 PM   #8 (permalink)
Woodzy88's Avatar
Canada
I as well purchased from nexgentuning. I purchased the 23mm and love it. It tightened my car up the ride is stiffer, quite noticeable, but I like it and its not (for me at least) too rough. I have also a set of Tien s techs for the Solara that I am putting on as well in the spring I’m getting anxious about that and also wondering if its going to be too low and too stiff for me. But time will tell. The 23mm is big, the nut on the end link bolt does not go on all the way but it’s only by about 2 threads. I just put some loc tight on it and its has been fine I check em every once and a while. Some guys ground the end of the sway bars down where the bolt goes but I would wonder about strength at that point.
Old 02-20-2011, 06:52 PM   #9 (permalink)
Gameroom cash: $324080
View Cartang's Photo Gallery
Yes I put 23 mm UR sway bar ,The shop fix the end link minimun issue , its a goos add.
Camry 99,SC 6psi,5sp,CPE intake,OBX headers, Jim's fuel system,Walbro pump, NST pulley,Greddy exhaust,Whiteline sways bars ,TRD strut bar,TRD shifter,Exedy clutch,Fidanza flywheel.
Camry2007 ,V6,SE,TRDcat back system, Fujita CAI,TRD springs ,UR(R) sway bar 23 mm,UR(F) 4 points,Lexus GS 430 rims.
Cartang is offline   Reply With Quote
Old 04-18-2012, 11:47 AM   #10 (permalink)
Realdamage's Avatar
View Realdamage's Photo Gallery
^Hi, where did you get the "metal clips" that hold the bushing, did it come with the bar? i bought a 19mm and it didnt come with it.. are the factory ones going to fit?
Every driver thinks every other driver is crazy.
My MOD's
http://www.toyotanation.com/forum/10...od-thread.html
Realdamage is offline   Reply With Quote
Old 04-18-2012, 04:32 PM   #11 (permalink)
View rule62's Photo Gallery
My 23mm came with the clips. The factory ones work just fine though.
rule62 is offline   Reply With Quote
Old 04-19-2012, 12:31 PM   #12 (permalink)
Gameroom cash: $195750
View ImJustMe55's Photo Gallery
Here are a few links. One is a link of a review that 2011SECamry wrote up and the other is him talking about how it felt on the Streets of Willow road course track:
UR Front Strut Bar Installed & Rear 23MM Sway Bar Review
My 2011 Toyota Camry V6 SE Racing The Streets of Willow 1/14/12 *Video*
I hope this helps.
It's good to go fast, but even better to be able to stop!!
2007 V6 Camry SE: TRD Air Filter, Power Slot Rotors, Hawk PC pads, Techna-Fit Braided Steel Brake Lines
ImJustMe55 is offline   Reply With Quote
