HELP! Best way to remove this? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2011, 07:49 PM   #1 (permalink)
Bills07CamLE's Avatar
Gameroom cash: $220300
View Bills07CamLE's Photo Gallery
Unhappy HELP! Best way to remove this?
What would be the best way of removing this? Its a GPS mounting pad but I dont know if I can use Goo Gone or if I should use something else that wont damage the dash.
Bills07CamLE is offline   Reply With Quote
Old 02-20-2011, 07:53 PM   #2 (permalink)
CAMRY is my livelihood...
Kycamrymaker's Avatar
Gameroom cash: $118600
View Kycamrymaker's Photo Gallery
Don't use nothing u wouldn't use on your paint. Those dashes are painted to match the interior so anything harsh will take the paint off too.
2011 TMMK SE V6, Leather, Nav, Remote start, 10,000k 55w HL, 8,000k 35w FL, 17% tint, LED conv.
Kycamrymaker is offline   Reply With Quote
Old 02-20-2011, 07:56 PM   #3 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $612031
View Zembonez's Photo Gallery
Peel as much off as you can. Use the edge of a credit card to gently scrape it... then use goo gone or something similar to remove the glue.
Zembonez is offline   Reply With Quote
Old 02-20-2011, 07:58 PM   #4 (permalink)
Thanks guys! Ill try to peel as much of it off first but im affraid of using goo gone because I dont want it to stain the dash or anything.
Old 02-20-2011, 08:00 PM   #5 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Just don't soak the crap out of it and you'll be fine. The key really is to get off as much as possible before using the goo gone.
Old 02-20-2011, 08:02 PM   #6 (permalink)
lol cool thanks again!
Old 02-20-2011, 08:59 PM   #7 (permalink)
08 Camry - 11 Corolla
View Mainuh's Photo Gallery
Now you see it... now you don't
Had a Garmin mount on my old car I just sold to by my new Camry. I used a heat gun I used (sparingly) but a hair dryer might work too. Garmin uses 2 kinds of pads. One they call temporary and another they call permanent. Mine had the temporary and easily came off with a little heat. Then there was a bit of sticky left which a dab of goo-off took right up. I think the permanant ones come up a lot harder.
BTW, after several years my tan dash was a slightly different color under the GPS holder once it was removed.
Good luck!
Cheers,
Don
Mainuh is offline   Reply With Quote
Old 02-21-2011, 08:59 AM   #8 (permalink)
-Kenny-
Guest
Posts: n/a
View -Kenny-'s Photo Gallery
Glue Gone
Old 02-21-2011, 12:09 PM   #9 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $821521
iTrader Score: 16 reviews
View GT-R's Photo Gallery
Goo gone won't damage your dash, I've used it to remove moldings on my dash before, just don't scrub it too hard cause you'll scratch the dash.
GT-R is offline   Reply With Quote
Old 02-21-2011, 12:58 PM   #10 (permalink)
View NegativeTen's Photo Gallery
Try a hair dryer or a heat gun on low settings while prying.. or wait until a hot summer day. When the adhesive heats up, it begins to soften and will make peeling it off much easier.
NegativeTen is offline   Reply With Quote
Old 02-21-2011, 01:36 PM   #11 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
yeah you will definitely need heat to remove that, or to make it easier.
If you dont have a heat gun, you should invest in one, they are so god damn useful !
CamrySExxx is offline   Reply With Quote
Old 02-21-2011, 03:23 PM   #12 (permalink)
Yeah, a hair dryer or a good hot day would do the trick, try rubbing/rolling motions on it first. In plant we use a citrus cleaner on the IP to get anything off, beyond that it's repainted.
