How to adjust fog lights? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2011, 09:58 PM   #1 (permalink)
View RandyL's Photo Gallery
New 2011 SE: how does one adjust the OEM fog light beams up or down? Nothing in the owners manual about it and no adjustment screws visible from the front.
RandyL is offline   Reply With Quote
Old 02-23-2011, 10:01 AM   #2 (permalink)
Gameroom cash: $246200
View fatngs's Photo Gallery
did u check behind them? my 06 has a 8mm bolt near the bulb socket to adjust the beam
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
fatngs is online now   Reply With Quote
Old 02-23-2011, 10:05 AM   #3 (permalink)
I did not check behind them as there is a panel under the front that would need to be removed first. Are they adjustable from the back?
Old 02-23-2011, 10:07 AM   #4 (permalink)
i would think they should but i have a gen 5.5 so i'm not 100% sure
Old 02-23-2011, 10:42 AM   #5 (permalink)
molson.david's Avatar
Gameroom cash: $295153
View molson.david's Photo Gallery
there is holes in the dust covers, attached to the bumper, right under foglights.you need to look from under the bumper.
get long phillips screwdriver.
right above those holes small size + bolts in foglights housing.
turning them clock wise will lower beam, counter clockwise-rise it.
IndianaBorn gen7 LE.
For sale gen 6:
MdxTSXr black shrouds 5K retro
OEM key with transmitter
2.4 transm.filter+gasket+WS.
2.4 K&N drop-in+cleaner and oil
molson.david is offline   Reply With Quote
Old 02-23-2011, 10:56 AM   #6 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $477210
iTrader Score: 12 reviews
View bandit's Photo Gallery
Why would you need to adjust them to begin with?
CarDomain
Old 02-23-2011, 11:14 AM   #7 (permalink)
Great, thank you!
Old 02-23-2011, 11:17 AM   #8 (permalink)
I believe they are adjusted too low. I know that with foglights they should be aimed level - if they are aimed up at all they will reflect back off anything in the air into the driver's eyes. Mine appear to be adjust to low however, I'll cover up the headlights and check them against a white wall here soon: measure the beam top from the ground just in front of the light, then adjust to replicate that height maybe 40' out.
Old 02-23-2011, 06:02 PM   #9 (permalink)
must.resist.modding
bandit's Avatar
If the fogs came from the factory, its already adjusted to its correct height. There is no need to adjust. Adjusting it higher will just blind on coming traffic. The fogs are not meant to be headlights and are closer to the ground for a reason.
CarDomain
Old 02-23-2011, 10:12 PM   #10 (permalink)
270hp = Happy Foot
Gameroom cash: $396245
View aznlunatic206's Photo Gallery
^ x10000000000000
2011 Camry SE V6 Fully Loaded w/o Navi
V-HIDS 5000k HID Kit Low Beam, 3000k Nokya Fogs
20% Aegis Tint, 50% Front Windshield
Tein Solara Springs on KYB GR2's
aznlunatic206 is offline   Reply With Quote
Old 02-23-2011, 11:03 PM   #11 (permalink)
Gameroom cash: $186285
View badbadtz560's Photo Gallery
I'm actually about to adjust mine way up. It's my drl/highbeam along w/ my mh1 projectors...but soon it'll double as a road sign lighter. I'm gonna put it in everyone's eyes since it runs on drl signal until I hit the high beams then again it's only gonna work as a road sign lighter with reduced brightness when I'm usin my rx330s (parking light mode)... and i typically run only mh1s
my pt bein that everyone has their reasons to do stuff.. don't be hatin
Here's what it looks like from under the car.. u can see that OEM-style fog light and there's a big + for the philips screwdriver.
U don't have to remove the black plastic shielding.. there's a big circular hole on each side for your adjustments
and plz don't run hids in the fogs like the pic shows was an old pic of me messin around
badbadtz560 is offline   Reply With Quote
Old 02-24-2011, 10:01 AM   #12 (permalink)
Thank you!
Old 02-28-2011, 12:55 AM   #13 (permalink)
View Bobmws's Photo Gallery
Fog lights wired to parking lights?
Is there a way to change the fog light relay trigger to pick up from the parking lights? My commute takes me along 9 miles that is frequently fogged in, like pea soup! I get alot of glare return from the headlights in that situation and would like to run the fog lights alone.
Bob W
Astatula, FL
'11 XLE, '10 Corolla
'65 El Camino-chopped & dropped
A bike or two......
Bobmws is offline   Reply With Quote
Old 02-28-2011, 01:07 AM   #14 (permalink)
use that red wire(fog switch) and tap in to the parking light wire.. the easiest access pt is probably from the tires - u can stick your arm in and pull the parking light out to tap it... but remember if u put it in parking light mode, you'll get glare from the DRLs
I actually found that the low beams had less glare than the DRLs that one time I had heavy fog in atlanta b/c the DRL scatters light further upwards.. but atleast if the drl glared more, u could jsut swap it back to low beams
The Following User Says Thank You to badbadtz560 For This Useful Post:
Bobmws (02-28-2011)
Old 02-28-2011, 05:28 PM   #15 (permalink)
I hadn't considered the DRL's being on in parking light mode, but I can see that the pattern would be higher and reflect more than the projector low beams. I'll try the parking lights with the DRL's and see what the pattern is on my tree lined road with no street lights. Thanks for the info.
If the DRL pattern is scattered higher I'll probably leave things as they are, maybe try a yellow fog bulb (not HID) if I get ambitious.
Bob W
Astatula, FL
A bike or two......
