wut in the world is this noise? (engine) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-28-2011, 03:32 PM   #1 (permalink)
Gameroom cash: $246200
View fatngs's Photo Gallery
Gen5 wut in the world is this noise? (engine)
06 camry SE 2.4 65k US built
engine maint: pcv, throttle clean, k&n intake just done; NGK IR plugs @ 50k (just for the hell of it); water pump & tensioner @ 47k; oil changes every 5k synthetic since around 40k, owned since 33k; history shows headers & 1st cat were replaced @ dealer before i got it and 2nd cat along with resonator and muffler were replaced after accident at about 51k (not sure if either o2 sensors were replaced)
MIL light is NOT on
i shot a video of the noise..... its coming from the top of the engine around the coils/fuel rail
the video amplifies the noise a bit but it sounds accurate
i scanned the engine with the good code reader from my store (advance) and it came up with cylinder 4 misfire *PENDING*..... i cleared it and went back today to see if it was back and it wasnt
i have a feeling its a coil but what do you guys think? saying it is a coil what brand do you recommend?
forgot to add: ive also notice a random burning smell coming from the engine bay and a tiny bit of random white smoke coming from somewhere on top (only when hood is up)
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
fatngs is online now   Reply With Quote
Old 02-28-2011, 05:40 PM   #2 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
Might be headbolts man. Especially with the white smoke and burning smell. It wouldn't be a misfire on all cylinders if it were one coil. And I doubt they're all bad.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 02-28-2011, 06:16 PM   #3 (permalink)
ouchhh i pray its not the head bolts lol
Old 02-28-2011, 07:25 PM   #4 (permalink)
Gameroom cash: $137274
View johnfrisco's Photo Gallery
If it is a head bolt issue it would be the first of me hearing/reading it happening on a 2006. And with so low miles I would be surprised.
How's your coolant level?
johnfrisco is offline   Reply With Quote
Old 02-28-2011, 08:37 PM   #5 (permalink)
coolant is ok..... hvnt had any problems with the cooling system except the water pump taking a crap
the engine really hasnt felt any different or less powerfull..... i dnt think the fuel mileage is great but i do have a lead foot
i really have a feeling its either something with the fuel rail or a coil
Old 03-01-2011, 05:14 PM   #6 (permalink)
a buddy at work pulled off the hose to the pcv valve and the engine stalled..... he told me to exchange the pcv so i did and the noise is still there..... i'm gunna pull the plugs 2moro when fixing my brakes and see if perhaps one is fouled.... i purchased new NGK IR premium plugs just in case
Old 03-02-2011, 09:25 PM   #7 (permalink)
replaced the plugs just for the hell of it..... the ones in there looked ok and had normal wear
my buddy thinks its that fuel regulator on top near cylinder 4 on the fuel rail..... i'll have to check around on how to change it and where i can get it (i hava feeling its a dealer part)
Old 03-04-2011, 11:51 AM   #8 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
View RICO8458's Photo Gallery
sort of sounds like a grinding noise? or electric generator noise? i hear a similiar, not the same, but similiar thing on mine, but very good vid on the issue.
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
RICO8458 is offline   Reply With Quote
Old 04-06-2011, 04:43 PM   #9 (permalink)
well the noise is still there......... my buddy took a automotive stethescope lookin thing and said it was coming from the fuel rail
do u guys think i should replace the injectors? i can get reman ones for about 30 a piece off rockauto; my boss said i should just leave it because the car doesnt have any loss of power or anything (btw im averaging 21-22 mpg with a lead foot)
one thing i noticed today tho... i had my A/C blasting today and the noise went away when the compressor was engaged and came right back when it cycled off
Old 04-06-2011, 04:48 PM   #10 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1077958
iTrader Score: 7 reviews
Maybe the lead foot is the problem.... take it easy! That is horrible mileage for the I4... i get 35mpg on my V6...and i do a lot of track days and still average around 25-28 on those days.
2002 Camry SE V6 "Snow White"
Old 04-06-2011, 04:54 PM   #11 (permalink)
PRNDL's Avatar
View PRNDL's Photo Gallery
Sounds like a vacuum leak to me...ck the hose on the left behind the first injector...looks like it's pulled off a bit.
2011 Camry XLE V6 w/Nav and pretty much everything else.
1971 Corvette...Frame off restored
2010 Honda Accord Coupe (wife's car)
PRNDL is offline   Reply With Quote
Old 04-06-2011, 06:05 PM   #12 (permalink)
the pcv hose seems pretty tight.... the noise sounds electrical to me
Old 04-06-2011, 11:40 PM   #13 (permalink)
Gen 5 SE Camry
View Dapuzzlar's Photo Gallery
That is soo strange. My 02 Camry SE I4 just started making the exact same noise about 6 months ago. I cant figure it out either but it started right after I changed the PCV valve.
Dapuzzlar is offline   Reply With Quote
Old 04-07-2011, 05:22 PM   #14 (permalink)
View devind05's Photo Gallery
07 camry also started making noise when I auto-start my car from remote and I hear almost similiar but it goes away after 5-10 mins.
devind05 is offline   Reply With Quote
Old 04-08-2011, 09:30 PM   #15 (permalink)
i think i might grab a new hose clamp from work and see if that changes anything
