2007 Camry V6 Oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-03-2011, 03:41 PM   #1 (permalink)
Registered User
View jackjackattack94's Photo Gallery
2007 Camry V6 Oil
Hello TN, I recently just bought a 2007 Camry V6 3.5 50,000 miles and I bought it from the dealer. The car fax said the oil was changed in it every 5000, on time, every time. And I have no idea what kind of oil it takes? I know it takes 5w-30 but is it conventional, syn-blend, or full syn? I plan on having this car for a while tho.
jackjackattack94 is offline   Reply With Quote
Old 03-03-2011, 04:03 PM   #2 (permalink)
Ted
mingming's Avatar
Gameroom cash: $386555
View mingming's Photo Gallery
If it was changed every 5000 it should be synthetic. Seeing how its a dealer, its probably regular.
work eurolines
mingming is offline   Reply With Quote
The Following User Says Thank You to mingming For This Useful Post:
jackjackattack94 (03-03-2011)
Old 03-03-2011, 04:19 PM   #3 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
2007 Camry V6=5w30 Dino oil (non synthetic), every 5,000 miles
If it were mine I'd do synthetic, but it's not required.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
The Following User Says Thank You to arabianobsession For This Useful Post:
Old 03-03-2011, 05:17 PM   #4 (permalink)
Gameroom cash: $202800
View Donald E. George's Photo Gallery
Mobil I 0W-30 will work just fine for 5000/6 months oil changes. If the oil and filters were changed every 5000 miles,your car will have many thousands of miles of service. Regards
Donald E. George is offline   Reply With Quote
Old 03-03-2011, 05:21 PM   #5 (permalink)
Toyota Parts since 1981
Gameroom cash: $148255
View DOHCammer's Photo Gallery
I use 5w30 Mobil 1 in my V6 and I swear the engine is a little quieter than when I first got it (I bought mine used also) and had conventional oil in it. I've been using Mobil 1 in everything I've owned for the last 15 years and have never had a oil related problem. I even use it in my air cooled engines (snowblower, lawn mower and tractor). The most noticeable difference comes when you start the car in temps lower than 10 degrees. Engines crank over like its still warm out. Hey, if you can afford it, use it!!
05 Highlander V6 AWD
170K miles young
07 Camry SE V6 SOLD!!
TRD Dual Exhaust & Air Filter
DOHCammer is offline   Reply With Quote
Old 03-03-2011, 09:14 PM   #6 (permalink)
Registered User
So even if the car has conventional in it do you think it is too late in the game to change to syn oil? And if I were to change to syn oil would it hurt the engine?
Old 03-03-2011, 09:17 PM   #7 (permalink)
Registered User
So do you think i will have engine issues? Right now it taps a little the first minute or so i drive it but then goes away is that a bad sign?
Old 03-04-2011, 07:43 AM   #8 (permalink)
View Thunnda's Photo Gallery
I wouldnt say its a problem. I do believe its common on the V6's. Mine taps very gently as well, but as soon as the engine reaches proper temp, its quiet..very quiet
White
SE V6
Thunnda is offline   Reply With Quote
Old 03-04-2011, 09:30 AM   #9 (permalink)
Need For Speed
No, and no. You can actually change to synthetic at any time you want. Just remember if you have some sort of gasket leak, the synthetic will make it more pronounced (but it does not make it worse).
jackjackattack94 (03-04-2011)
Old 03-04-2011, 10:22 AM   #10 (permalink)
I'm not sure what the cold clearances are on the 2007 but my 2004 V6 has .006-.010 on the intakes and .010-.014 on the exhaust valves. You have to expect that you are going to hear some noisy from the valve train with 24 valves. The old V8s with adjustable rockers made all kinds of noisy until they warmed up and even when up to operating temp. Regards.
Old 03-04-2011, 12:53 PM   #11 (permalink)
molson.david's Avatar
Gameroom cash: $295153
View molson.david's Photo Gallery
isn't all 2007 and up toyotas comes with syn.blend oil?
that supports 5K intervals. on regular 3K, on full syn, 8-10-12. some recomend to change filter half way.
IndianaBorn gen7 LE.
For sale gen 6:
MdxTSXr black shrouds 5K retro
OEM key with transmitter
2.4 transm.filter+gasket+WS.
2.4 K&N drop-in+cleaner and oil
molson.david is offline   Reply With Quote
Old 03-04-2011, 12:55 PM   #12 (permalink)
Need For Speed
^No, only since 2010 has Toyota been switching to synthetic oil. Even the current 2011 Camry V6 is still 5w-30 dino oil. They 4 cylinder comes with 0w-20 synthetic.
Old 03-04-2011, 05:41 PM   #13 (permalink)
This a common 3.5 V6 characteristic. The pistons in this engine are a loose fit and the engine develops piston slap on cold startups. As soon as the piston gets a little heat in them they expand slightly and the rap goes away. Usually only takes a minute or two and no harm is being done to the engine. Synthetic oil does not help this noise whatsoever, only heat takes away the rap. The valvetrains are also a little on the noisy side and this is what the synthetic oil helps through reduced friction.
170K miles young
The Following User Says Thank You to DOHCammer For This Useful Post:
Old 03-04-2011, 09:56 PM   #14 (permalink)
View Hennessy Hek's Photo Gallery
I know Syn. oil is good for areas that get cold but anyone know is its good for warm areas??? never gets below 40 here and i dunno if syn is good under all yr around heat
Hennessy Hek is offline   Reply With Quote
Old 03-04-2011, 11:37 PM   #15 (permalink)
Registered User
So i live in an area where it gets down to 5 degrees and upwards of 100 degrees. Do you think full syn provide more protection? I called the dealer from where I bought it, they said they use syn-blend. Is it worth the extra money for full syn?
Tags
type of oil
