2003 Camry V6 Start problem- i thought... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-03-2011, 09:00 PM   #1 (permalink)
View rk1407's Photo Gallery
Hi guys, need some help with this one.
I turn the key on my Dad's 2003 V6 Camry and nothing happens, no clicking or anything. I thought it was the starter solenoid so since I couldn't find just a solenoid I bought a remanufactured starter/solenoid. I installed it tonight and the results were the same, nothing!
I know the battery is fine, it is relatively new (less than a year). I can hear the fuel pump start and the lights and radio come on.
I looked at the fuse box but I really couldn't determine which fuse it was. I saw an ignition fuse (15amp) but I couldn't even pull it out with a long nose pliers and I don't have the proper puller. Should I be looking a fuse or relay? Thanks in advance for your suggestions...
rk1407 is offline   Reply With Quote
Old 03-03-2011, 09:30 PM   #2 (permalink)
Gameroom cash: $246200
View fatngs's Photo Gallery
test the battery! even tho its relatively new, its not uncommon for some batteries to go bad relatively young.... i get a few every couple months at my store; it should still be under warranty
also check the battery cables and terminals
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
fatngs is online now   Reply With Quote
The Following User Says Thank You to fatngs For This Useful Post:
rk1407 (03-09-2011)
Old 03-04-2011, 11:04 AM   #3 (permalink)
Gameroom cash: $202800
View Donald E. George's Photo Gallery
Look in the owner's manual to see where the starter relay is located. Probably in the underhood fuse/relay box.Test it with a multimeter using the ohms function. Regards
Donald E. George is offline   Reply With Quote
Old 03-04-2011, 12:33 PM   #4 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352560
View gdanaher's Photo Gallery
What is the static voltage of the battery??
gdanaher is offline   Reply With Quote
The Following User Says Thank You to gdanaher For This Useful Post:
rk1407 (03-09-2011)
Old 03-09-2011, 10:44 PM   #5 (permalink)
Nice call..
Turns out the battery cables were corroded on the positive terminal. There are two cables that get sandwiched together on the pos terminal. The one going to the starter was corroded and not making contact. The cable powering the main fuse box was fine and this is why the radio, lights, and everything else came on. So I cleaned up the cables and terminal, greased them up good and it works great.
Thanks again..
Old 03-09-2011, 10:50 PM   #6 (permalink)
yea i had tht problem with a POS caravan i had.... tht was a fun drive when my electrical system decided to take a crap whenever it felt like it
