couldn't start after stopping for half hour, engine analysis found nothing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-05-2011, 09:51 PM   #1 (permalink)
View frankluo's Photo Gallery
Gen5 couldn't start after stopping for half hour, engine analysis found nothing
2003 V4 Camry LE, 85K miles.
It happened to me three times within two months. After driving for 20-50 minutes, stop for 15-30 minutes, then the car cannot be started. When I turned the key, the engine was making some noise, just would not start. But a jump-start always worked, and after being jump started, I cannot get the car to stall again. It all happened in a relatively cold weather in Texas, which is around 40-50 degrees, but not sure if it is just a coincidence.
It sounds like a bad battery, but I had it checked twice and it appeared to be good. I even paid $80 to Firestone to have them run a engine analysis on it and still found nothing.
Check engine light wasn't on, but a fault code was reported: P2238. Firestone didn't want to fix it, but suggested me going back to dealer to fix.
So any idea?
frankluo is offline   Reply With Quote
Old 03-06-2011, 03:49 AM   #2 (permalink)
Somewhat a Lurker
Gameroom cash: $311669
View Agent556's Photo Gallery
http://www.dtcsearch.com/P2238/
sounds like an issue with the O2 sensor
as for the battery, if it's good then it may just have a low charge. Don't think its the starter if you heard it trying to start and it starts fine on a jump start.
2005 Camry SE V6
http://www.toyotanation.com/forum/sh...d.php?t=343592
Agent556 is offline   Reply With Quote
Tags
stall code weather p2238
