Replace LE Instrument Cluster with SE Cluster 2004 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2011, 12:34 PM   #1 (permalink)
View Mcglry's Photo Gallery
Gen5 Replace LE Instrument Cluster with SE Cluster 2004 Camry
i Know how to remove the instrument cluster, but what will happen with the Mileage on the ODO? Does it just change by itself? Can i add a 2005 Camry Cluster instead?
5th Gen 04 Camry LE I4
91500 Miles
SE Headlamps
16" rims
(Stock Toyota Camry Hybrid)
Mcglry is offline   Reply With Quote
Old 03-06-2011, 03:30 PM   #2 (permalink)
I Has Mods To Do
Gameroom cash: $178092
View coolhandsean's Photo Gallery
Depends if the Gen 5 stores the mileage in the ECU? I know the Gen 6's do but even that still requires a recalibration at the dealership once installed. It is possible in any case, just may or may not require additional steps/$$$ at the dealership. I'm sure you know this but the most important thing is to make sure you have the correct cluster for your engine size or it will be off. Ex. Gen 6/6.5 cluster for 3.5L goes to 160 mph but the 2.4/2.5L only goes to 140. Good luck bro, hopefully someone with a Gen 5 could answer your question.
coolhandsean is offline   Reply With Quote
Old 03-06-2011, 06:03 PM   #3 (permalink)
Gameroom cash: $246200
View fatngs's Photo Gallery
1: 2.4 and 3.0 seem to have the same cluster, 3.3 has a lower redline
2: not sure about mileage being on ecu..... i guess u could ask the dealer?
3. a gen 5.5 should fit BUT the connections are probably different; also gen 5.5 has backlighting that is constantly on
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
fatngs is online now   Reply With Quote
