2005 Tacoma Headlight (Daytime Light Lens) are cracked - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2011, 02:19 PM   #1 (permalink)
View tophatchief's Photo Gallery
I have found both my left and right side day running light lens (amber) cracked. The Toyota Service dept. is asking $915.00 to change bothe the headlight assemblies. Due to the front bumber needing to be removed, before the headlight assemblies can be removed.
Can someone tell how to remove the bumber in order to remove the headlight assemblies?
Thank you very much.
tophatchief is offline   Reply With Quote
Old 03-06-2011, 02:52 PM   #2 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
Gameroom cash: $530410
View BlackCam09's Photo Gallery
wrong section?
Pioneer 7" AVH-P4200DVD|CDT Audio 6.5" CL-62Pro Comps|Alpine SPR-69C 6x9s |09 RD Alpha 15" in 2.75ft^3 @34hz |Sundown Audio SAZ1500D|Kicker ZX250.2|UR Strut Bar|H&R Springs|EE LED Tails|18" Konig Crosshair|RX330-TSX-R Clear lens Retrofit|Megan Catback|RKS Kit|UR 19mm RSB|BC Racing Coils
BlackCam09 is online now   Reply With Quote
Old 03-06-2011, 03:28 PM   #3 (permalink)
HI, Thanks! But, this reply did not help. I still need advice/instruction on how to remove the Front Bumper in order to remove both headlight assemblies.
Old 03-06-2011, 03:29 PM   #4 (permalink)
Old 03-06-2011, 04:02 PM   #5 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
well how are we suppose to help you when none of us have a tacoma truck? this is the camry section so we would know nothing on how to remove it thats why your better off posting in the tacoma section.
Old 03-07-2011, 09:44 AM   #6 (permalink)
theslowone's Avatar
View theslowone's Photo Gallery
you do not have to remove bumper on the tacoma
remove grill and lower filler piece pops off and oh here
First, you need to start with the removal of the stock grill. It's pretty simple: start by removing the 2 top 10mm bolts on the stock grill. Then, use a flat head screwdriver to pop up the black gourmets that are also on top of the grill. The grill will pull straight up and now that is out of the way. Start removing all fasteners and 10 mm bolts that are attached to the headlights and grill. You can avoid lowering the bumper which is a PITA and get to the last headlight bolts from under the truck. You need to reach up and get the last bolt with a 10mm wrench.
i have took a couple out no problem u just have to twist.
save some money and do this.
http://www.customtacos.com/tech/index.php?article=223 or
http://www.customtacos.com/tech/index.php?article=222
but if your gonna buy new get some 09+ trd smoked chrome lights.
but here if u really want to remove the bumper.
http://www.customtacos.com/tech/file...06ta/06300.pdf
2007 se I4 leather and all + trd wheels
2009 tacoma v6 4x4 trd sport plus a few features
1998 tacoma i4 4x4 base 284k and toyota took him out
1981 pickup 4x4 solid axle 22r 5 speed long bed and 4.88 gears w/ 170k
theslowone is offline   Reply With Quote
