I bought a 2002 4 cyl Camry. The purchase was 'as is'. Love the car, but now I have an oil leak. The car has around 130K miles on it, but the engine was replaced with one from a wreaked Camry with around 60K miles on it. The car runs great. But, the oil leak seems to be coming from the front engine seal(s). By front, I mean the side, where the belts are. It is not the valve cover gasket, if I remove the tire, I can clearly see oil on one the pulleys, and dripping down onto the side of the oil pan.
What will I be looking at labor wise to replace the front seals? I did some research, and it seems to be a good idea to replace the belts, and the other front seals when I get this done. Any estimate on cost, or even shop hours for it would be good to know. Also, as I am guessing this is a pretty labor intensive job, are there any other gaskets or parts that I should replace? Gaskets are cheap, labor is high. With my luck, I would get one fixed, and 2 months later have a different one spring a leak. Would rather cry once.
Maybe $500-600 labor i am guessing?
Change the timing belt while you are at it. Even if it got changed recently it's oil soaked.
Change at a minimum the front crank seal, and the front camshaft seal. You may want to change the oil pump seal too, ask the mechanic's opinion.
two hours of work. $80-100/hr. Try to negotiate w/ that or call Toyota, honda, or other dealer and see how many hours does it takes to replace those seals.
Seals cost couple of $tens for all front seals, not much. Check your local autoparts.
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
Well, that is promising. If it is just $500 to $600 for labor, would be nice. And yes, plan on replacing all the front seals, the timing belt, and the other belt(s) as well. I think I will call the Toyota dealer Wednesday, see if they will give me a quote over the phone. I just want it fixed, would rather cry once than try to go cheap, fix one leak, then spring another 3 months later.
I was quoting California prices, everything is expensive here. Profuse 007 may be right, in your section of the country you may find a shop willing to do it for less, maybe a lot less.
You are doing essentially a timing belt and seal change, the parts for this are timing belt ($30-40) and 2 or three seals ($30-50 for all three) plus the labor (at least half a day i am guessing).
And if you want to have it done while everything is apart, have them change the water pump and idler pulleys too (another $200-300 for parts). If you can't afford the water pump and/or the old one seems ok, i'd recommend to change the idler pulleys at least (maybe $50-100 for both).
Thanks for the info. Shop rates are pretty high here, I know the Nissan dealer is charging $100 and hour for labor. And also, thanks for the info on the water pump and idler pulleys. I would rather add oil for a few weeks while I save up and get a bunch of potential problems solved. I plan on stopping by a shop to get an estimate Thursday or Friday.
I changed the oil Sunday, and have been driving it more than normal to get an idea on how much oil is leaking, and as of this morning, a few drips on the carport, and the oil level is pretty much full, no noticeable oil loss on the dipstick.
I remember looking at a ASE book saying non-luxury labor is 80-100 in USA. In houston here, toyota and honda near me charge 90-95/hr. Hondas around here have a lot of coupons for parts and repair you can use but Toyota sucks at that. It seems like it's cheaper to repair honda than toyota around here.
OP says he has an 02 I4 Camry. These engines (2AZ-FE) don't have a timing belt, but instead have a timing chain. Its def more complicated to replace a timing chain than a belt, but YES, I would replace the gaskets, seals, other belts, etc...while you're in there.
Hmm. I was told it had a timing belt. How do I tell if it has a timing belt or chain? The engine actually was replaced. I am not sure exactly what year the engine came from.
I have two Gen 5 Camrys (03 and 05) and they both have the 2AZ-FE engine. This engine has a timing chain, and I believe the manual recommends it to be replaced every 90k. Here is the manual for the 2AZ-FE section just to let you know you have a chain.
Whether you replace it is another question because I don't really know where your leak is located. IF it is near the timing chain and the mechanic is replacing the seals around that area, I would go ahead and replace it. Might as well do some preventative maintenance. Sorry for not giving you clear cut answers as I work on my older Camry and these newer ones haven't had a problem yet.
I guess I may have a mutant Camry. The guy that owns the shop that replaced the engine advised me to replace the timing belt. I don't know how to tell if it has a timing belt or chain. I think I found someone who has a lot of experience working on Toyota's who will do the work for around $300. Will get him to check out the engine to see what it has.
Ehh, my guess is the mechanic doesn't know Camrys, at least not the 2AZ-FE engine. Either that or he doesn't distinguish a belt from a chain, but thats really not the point. Change it if he will be replacing stuff around there, it doesn't hurt.
I must admit, I am a bit confused now. But that is normal for me and cars, I do very little work on them, and my days working in a shop are over. Is there any way I can identify the engine that is in the car? It says it has 16 valves, so I am guessing not a V6. But I have no idea what year model engine they put in the car. Surely the engine is stamped somewhere.
Thanks a lot for the info! Had it checked out today, my car has a 2003 engine, that has a timing chain, not a timing belt. So, I am told there is only the crank seal and belt(s) to worry about, so it will be a lot less cash to get it fixed!
I am not a mechanic, and know that. I will change my oil, plugs, disc brake pads, hoses and simple stuff. When it comes to real repairs, I am clueless.
