Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2011, 05:38 PM   #1 (permalink)
Will
willt's Avatar
iTrader Score: 7 reviews
View willt's Photo Gallery
Question
pls dont move it thanks
well i just need quick answer getting this but not sure how to install it should i put it on middle part or under or top of the coils?
http://www.jcwhitney.com/ring-type-c.../p2005889.jcwx
oh its called CP AUTO PRODUCTS RING-TYPE COIL SPRING STABILIZER
L-OO-k at MEE...
willt is offline   Reply With Quote
Old 03-07-2011, 05:44 PM   #2 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
Gameroom cash: $530410
View BlackCam09's Photo Gallery
link just goes to the jcwhitney.com homepage bro.
Pioneer 7" AVH-P4200DVD|CDT Audio 6.5" CL-62Pro Comps|Alpine SPR-69C 6x9s |09 RD Alpha 15" in 2.75ft^3 @34hz |Sundown Audio SAZ1500D|Kicker ZX250.2|UR Strut Bar|H&R Springs|EE LED Tails|18" Konig Crosshair|RX330-TSX-R Clear lens Retrofit|Megan Catback|RKS Kit|UR 19mm RSB|BC Racing Coils
BlackCam09 is online now   Reply With Quote
Old 03-07-2011, 05:54 PM   #3 (permalink)
Will
willt's Avatar
well i put pic and the name cause when i put the exact link it doesnt go straight to the item
L-OO-k at MEE...
Old 03-07-2011, 07:37 PM   #4 (permalink)
gator1939's Avatar
Gameroom cash: $245335
View gator1939's Photo Gallery
Quote from description on JCW website
QUOTE
Nylon-reinforced rubber?follows curve of spring. Place one stabilizer ring under each coil spring for up to 2" of lift. Can also be twisted in between coil.
UNQUOTE
gator1939
2B1ASK1
gator1939 is offline   Reply With Quote
Old 03-08-2011, 02:19 PM   #5 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
http://www.jcwhitney.com/ring-type-coil-spring-stabilizer/p2005889.jcwx
The last time I used the Urethane rings. If you want the highest raise then position the ring at the lowest position in the coil. And vice versa, if you want to raise the car just a little then install the ring at the highest position in the coil. Good luck buddy.
Old 03-08-2011, 04:55 PM   #6 (permalink)
Will
willt's Avatar
thanks for the replies
@ lammy i found a urethane ones but i have to measure the width of the springs iam hoping it will be around 5. or 5.5
L-OO-k at MEE...
