E-brake wire for dvd install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2011, 10:59 PM   #1 (permalink)
View wscottchris's Photo Gallery
I have a 2005 camry and installed a new indash dvd/radio. Everything works fine except the dvd. I do not wish to mod it with switch or relay. I cannot locate the e-brake hot wire to tie the green wire into so the dvd works when we are stopped. Is it behind the dash somewhere or will have to fish it through the center console?
wscottchris is offline   Reply With Quote
Old 03-08-2011, 11:27 PM   #2 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
Check on the ebrake it self, and around that area, i would assume there to be a wire coming from the ebrake.
What kind of unit is it ? Do you need to do certain steps for it to make sure your in park? Like the alpine units where you must touch the brake pedal and pull the ebrake?
If not just ground the wire. Just dont turn the video portion on while driving :P
CamrySExxx is offline   Reply With Quote
Old 03-09-2011, 04:30 AM   #3 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
Gameroom cash: $530410
View BlackCam09's Photo Gallery
x2 just ground ebrake wire works like a charm. Ive done it to all my indash install and works everytime, if that doesn't work just go on ebay and look for a relay wiring its not a mod all you have to do is connect 3 wires.
Pioneer 7" AVH-P4200DVD|CDT Audio 6.5" CL-62Pro Comps|Alpine SPR-69C 6x9s |09 RD Alpha 15" in 2.75ft^3 @34hz |Sundown Audio SAZ1500D|Kicker ZX250.2|UR Strut Bar|H&R Springs|EE LED Tails|18" Konig Crosshair|RX330-TSX-R Clear lens Retrofit|Megan Catback|RKS Kit|UR 19mm RSB|BC Racing Coils
BlackCam09 is online now   Reply With Quote
Old 03-09-2011, 05:03 AM   #4 (permalink)
new11owner
BluTorrent's Avatar
View BluTorrent's Photo Gallery
y dnt u want to use a relay? its the easiest thing possible, plus no switches or holes to cut, its automatic, jus hook ground and remote turn on to it and it will trick the unit into thinkin u set ur parking brake, unless ur using a higher end screen like z-120bt or somethin where u gotta move the mute wire a pin over and connect it to the parking brake wire and then ground it
but as far as the e-brake wire, it will b on the ebrake itself, theres only one wire so u cnt mess up
BluTorrent is offline   Reply With Quote
Old 03-09-2011, 06:44 AM   #5 (permalink)
Banned
Gameroom cash: $216100
View BlackG5's Photo Gallery
I had to move the mute wire on my wiring harness over one spot, and ground it, to get my Avic-D3 to play DVD's while driving...
different units have different ways of bypassing, just look it up..
BlackG5 is offline   Reply With Quote
