A/C problem in 2003 Camry XLE V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-10-2011, 02:29 AM   #1 (permalink)
View aydj's Photo Gallery
My 2003 Camry XLE V6 Japan Made with 120K mileage is having A/C problem, these are the symptoms:
A/C does not cool when the car is idling.
A/C only cools at night when the car is moving.
I have replaced the refrigerant but no improvement in cooling.
No blinking A/C light.
No strange noise.
A technician suggested i should change the compressor but i'm skeptical.
Any suggestion?
aydj is offline   Reply With Quote
Old 03-10-2011, 08:50 AM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352560
View gdanaher's Photo Gallery
1. Are you trained for this work and licensed to handle refrigerants?
2. Describe your procedure for replacing the refrigerant.
3. What were the high and low pressures when charged and what was the ambient temperature.
4. Are the fans cycling on and off with the compressor?
5. Has the system ever been open and then not evacuated?
gdanaher is offline   Reply With Quote
The Following User Says Thank You to gdanaher For This Useful Post:
Donald E. George (03-10-2011)
Old 03-10-2011, 10:38 AM   #3 (permalink)
Gameroom cash: $202800
View Donald E. George's Photo Gallery
I can't discern where you live from your location but maybe you live in an area where you have high humidity with warm to high temperatures. It's normal for the AC not to put out as much cold air when idling,you don't have adequate air flow through the condenser. Check the lines running into and out of the evaporator at the firewall. The larger line should feel cool to the touch and the liquid line should be warm to hot. Have an AC specialist do the high/low pressure checks as gdanaher suggested. Also the dryer/filter in the condenser may have failed. Regards.
Donald E. George is offline   Reply With Quote
Old 03-10-2011, 05:05 PM   #4 (permalink)
1. A technician handled the refrigerant replacement
2. the fans are working well.
3. the technician replaced the dryer in the condenser.
but the situation did not improve.
Old 03-10-2011, 07:45 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
The technician obviously didn't know what he was doing. It's more common than you think.
Has he checked the evaporator temperature? Heater/vent control flaps?
Old 03-10-2011, 09:04 PM   #6 (permalink)
Maven
gdanaher's Avatar
I understood that air was blowing but it was warm air. Was I mistaken? Is the problem that of lack of air blowing through the vents? That is entirely a different issue.
If air flow is acceptable but is warm, the compressor is running, the radiator fans are running, the issue is most likely the compressor. Your repair guy surely put gauges to the system in order to charge it, so he must have seen the head pressure was low or the suction pressure was too high. If he said you probably needed a compressor, then he is likely making that prescription based upon the numbers he is seeing in his gauge.
Another issue. In recent years, Toyota has used a variety of oils in their systems and they are not all compatible. Mywife's RAV4 took a hit, the shop used the wrong oil, and 2 weeks later the compressor failed. Talk to Toyota to verify which oil should be used in the system.
Old 03-11-2011, 11:35 AM   #7 (permalink)
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Gameroom cash: $325400
iTrader Score: 12 reviews
View TOYOPARTSMAN's Photo Gallery
This particular year Camry also had some issues with the magnetic clutch Relay. The original part in the car(90987-02022) has been updated to a (90987-02028) and solves about 75-80% of the "AC not cooling or getting cold" complaints.
May want to check that as well.
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is online now   Reply With Quote
Old 03-27-2011, 12:10 PM   #8 (permalink)
Thanks for your replies,
I've been able to establish the fact that the compressor is bad and needs to be changed, but the technician is suggesting i change the evaporator, condenser and the expansion valve because of black residue in the system. Any suggestion?
Old 03-27-2011, 07:18 PM   #9 (permalink)
View JLCLVCATLMVA's Photo Gallery
What could cause the Heater/vent control flaps to not operate properly? All the air blows thru the vents and defrost vents.
JLCLVCATLMVA is offline   Reply With Quote
Old 03-29-2011, 07:55 AM   #10 (permalink)
I am going to go out on a limb and say that the black residue is some sort of mildew. Our store offers an AC refresh service that would eliminate that, if it is mildew.
678-854-9601
Old 03-29-2011, 07:57 AM   #11 (permalink)
First guess, A servo may be out, or the door is just stuck.
678-854-9601
Old 03-29-2011, 09:02 AM   #12 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
Sounds like you need more refrigerant. How much freon was sucked in?
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Tags
camry xle, compressor
