2003 Camry, never had any problems, 100k.
Now: could not start, everything are dead, even no horn, use a jump start, started, but went dead on first intersection. Went to Pepboys, check: buttery totally dead, replaced. Check alternator with special device - does not work. Replaced alternator( refurbished with total waranty). Started to drive, on first light, during idling, battery red icon appered, return to shop, the adjusted idling and apologyes. Started drive, again battery red ligh on dashboard came and car stoped. Retuned to Pepboys. They apologyes again and will check everything again.
Any suggestions and advices? Please help me. Thanks to everybody who will answer.
NM2
Does it have the 2.2 I4 engine? The 02-04 models are known to "forget" how to idle whenever the battery is disconnected. It take a while for it to "remember" and adjust back to the correct idle. Just try driving the car around for about 10 minutes with some highway miles and it should return to normal.
Also, I don't think the idle can be adjusted on the gen 5 Camrys.
Thanks a lot, Any other ideas, I just do not want Pepboys people reap me off and say change this, change that. I hope they chacked belt....
Will wait for your advice.
NM2
In reading your posts I am not certain if the altenator light comes on andthen the engine dies, or if the engine is idling so slowly that the alternator ceases to generate and the light comes on. Pleas clarify. But as stated, if the cars computer is disconnected from the battery it will lose its larned memory and when reconnected will boot back up with a default setting that might not be correct. drive the car for a period of time and distance--several miles. Stop and start it a few times over several hours. If the issue is the computer needing to relearn, it will cure itself. Beyond that it is easy to know if the electrical system is working simply by using a 3 dollar volt meter from Harbor Freight.
The Following User Says Thank You to gdanaher For This Useful Post:
It could be your starter also. I also had similar symptoms on my 02 Camry and NTB misdiagnosed my issue as a battery failure but it turned out that the starter was starting to fail.
