Help! Help! Help! Lateral link bolt out of Busing? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-13-2011, 09:30 AM   #1 (permalink)
View rclancy's Photo Gallery
Angry Help! Help! Help! Lateral link bolt out of Busing?
I have a 2007 Toyota Camry and need to replace the driver side Lateral link (bent) I can't get the bolt out of the control arm bushing! Any suggestion would be very appreciated. I've been pounding on the bolt and have used penetrating oil. It seem to have moved only about an 1/8 of an inch after beating on it for an hour!
rclancy is offline   Reply With Quote
Old 03-13-2011, 09:37 AM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397085
View RningOnFumes's Photo Gallery
Any room in there to get a breaker-bar (with extension) for extra leverage?
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is online now   Reply With Quote
Old 03-13-2011, 11:34 AM   #3 (permalink)
a_tov29's Avatar
View a_tov29's Photo Gallery
its not that its rusted right if so perhaps some PB blaster or just lighting it up with a propane torch could do the trick
a_tov29 is offline   Reply With Quote
Old 03-13-2011, 05:34 PM   #4 (permalink)
Unhappy Still No Luck
I tried a "pickle" fork, breaker bar, no luck.
I had this up on ramps and it was suggested that the weight of the car might be the issue. Put it on jack stands so no weight on the wheel, still won't come out. I afraid of putting a propane torch to it because I might ruin the rubber bushing. Any other suggestions out there?
Old 03-13-2011, 06:21 PM   #5 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352560
View gdanaher's Photo Gallery
It sounds very likely that since the arm is bent that the hinge portion might also be bent. You need another person to move it up and down while you hit it, OR you need to cut the bolt head off and start pushing from the other direction.
gdanaher is offline   Reply With Quote
Tags
2007 camry, desperate, lateral link
