Brake Noise needs help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-14-2011, 04:32 PM   #1 (permalink)
View camrycrazee's Photo Gallery
Hey everyone,
i need some help. Just recently changed(diy) the brake pads on my 2007 camry. After a month of driving it around with no problems. Im starting to exhibit some noises. First the noise only happened by turning the wheel all the way to the left and slowly letting the brakes go and kind of slowly brake. It's not consistent and would only happen randomly. Now the noise has moved to going straight also. If i were to go straight under 10mph and slowly brake, it would make noises. The noise i guess can be described as very similiar to the noise the wear indicator on the brake pads would make. Also the pads are oem toyota pads bought from the dealership.
I have taken the car to a trusted mechanic and the stealership but neither of them can replicate the sound.
camrycrazee is offline   Reply With Quote
Old 03-14-2011, 04:35 PM   #2 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
Gameroom cash: $530410
View BlackCam09's Photo Gallery
how many miles on the car currently?
Pioneer 7" AVH-P4200DVD|CDT Audio 6.5" CL-62Pro Comps|Alpine SPR-69C 6x9s |09 RD Alpha 15" in 2.75ft^3 @34hz |Sundown Audio SAZ1500D|Kicker ZX250.2|UR Strut Bar|H&R Springs|EE LED Tails|18" Konig Crosshair|RX330-TSX-R Clear lens Retrofit|Megan Catback|RKS Kit|UR 19mm RSB|BC Racing Coils
BlackCam09 is online now   Reply With Quote
Old 03-14-2011, 04:54 PM   #3 (permalink)
The car has around 56K.
Old 03-14-2011, 04:57 PM   #4 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
oh ok, i was going to say if it was less then or 36k i would take it in as warranty. I had my 09 camry brakes changed at like 28k under warranty. lol
Old 03-14-2011, 05:05 PM   #5 (permalink)
This one is actually very hard to figure out. I did take it to the dealership and they had no way to replicate the sound and i was without a car for like 3-4 hours. I talked to alot of people and spend alot of time researching but it seems like there could be so many possibility i.e. strut are shot, stuck sliding pins etc etc.
Old 03-14-2011, 05:07 PM   #6 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
yeah sorry man when it comes to cars there could be so many possibilities and factors involved.
Old 03-14-2011, 05:15 PM   #7 (permalink)
yeah im just trying to find the sweet spot where i can consistently have it make the noise so i can replicate it for the dealership or mechanic.
Old 03-14-2011, 06:22 PM   #8 (permalink)
View iamreggielee's Photo Gallery
Out of curiosity, where the pads chamfered or did you chamfer the pads when you installed them? Some pads come chamfered, the edges rounded out (think bicycle brakes), some don't! If yours didn't come chamfered and you didn't chamfer them, that can cause the brake squeal you are experiencing! Metallic particles get trapped between the flat edges of the pad and the rotor! By rounding out the edges, you give those particles a place to exit the rotor! Hope this helps you
iamreggielee is offline   Reply With Quote
