There are online Toyota dealers that sell for about 20-30% less. Gary here is a TN member seller. You can check with him on prices.
Otherwise your local NAPA store should carry Wix filter kit (filter+gasket). Rockauto.com also has it plus ATP and Beck Arnley. All under $20, plus shipping. (I don't know if Fram comes with a gasket any more. They used to).
Castrol Import Multi-vehicle ATF is a suitable substitute for T-IV (dino Mobil 3309). At Walmart the price is right.
Valvoline MaxLife ATF is also suitable for T-IV and WS. However, this fully-synthetic ATF is a thinner fluid formulated to match GM's Dexron VI (6) type fluids. Some like this fluid, but I personally stay away from the thinner fluid unless you have a 2007+. Of course
Walmart SuperTech Mercon-V is also suitable for T-IV, but it's only slightly less than Castrol.
http://www.castrol.com/castrol/secti...tentId=7028224
http://www.valvoline.com/products/br...ssion-fluid/37
Originally Posted by sundarpn
2002 Camry XLE. I have to get the PITA tranny pan dropped, filter changed and refilled.
Should I buy the filter kit from the dealer? or is there a good aftermarket brand?
Getting to 100K... did drain & fill via drain plug back at 50K. Fluid of couse I have to pay $$$ at the dealer for type-4
