I have noticed this sound for a while but havent had time to take it to the dealership. From a cold start, when you put the car in drive, there is a brief knock that comes from the front of the car. This only happens when you start to drive off. The intensity of the sound varies by day. Some days its quite loud and others its barely noticable. Interestingly though, the sound only happens after you put the car in drive. I back out of my driveway and it doesnt actually occur till I swap from R to drive and pull away. I called the dealership to schedule my first oil change and mentioned it and that i found a TSB that sounds pretty spot on to what is happening. The service tech told me he knows the TSB i am referring to, that the sound i am hearing has nothing to do with the TSB and that it has to do with the Anti-Lock brake pump initializing. He stated that this is just how these cars are. Now this sounds like a bunch of horse crap but then again i know nothing about brake pumps. I would think the brake pump would initialize the moment the car starts moving and not only when the car is put in drive.
Any thoughts? Has anyone else recognized this sound or had a similar problem?? I wanna be able to tell this guy he is full of crap if in fact he is.
Njerald posted the below TSB back in december and i think this is the actual problem.
T-SB-0146-10, Brief Engine Knock/Rattle Noise at Cold Startup, dtd. 6/910
2010 – 2011 Camry Engine(s): 2AR Transmission(s): 6MT, 6AT
2009 – 2010 Highlander Engine(s): 1AR Transmission(s): 6AT
2009 – 2010
RAV4 Engine(s): 2AR Transmission(s): 4AT
2009 – 2010 Venza Engine(s): 1AR Transmission(s): 6AT
Immediately following a cold soak startup, some 2009 – 2011 model year vehicles equipped with the 1AR-FE and 2AR-FE engines may exhibit a brief knock/rattle noise from the engine compartment for
approximately one second. Follow the repair procedure below to address this condition.
3.5 Hours to replace camshaft timing gears,,
