Fog Lights work Independently? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2011, 11:25 PM   #1 (permalink)
robertalpha00's Avatar
View robertalpha00's Photo Gallery
Gen6 Fog Lights work Independently?
Hi guys, I have a Toyota Camry 2010 SE and was thinking if my fog lights have any chance to work independently. I was surfing the web and some guys do in other models.
My question is, if any of you guys post a DIY for this kind of mod?
robertalpha00 is offline   Reply With Quote
Old 03-20-2011, 12:04 AM   #2 (permalink)
'11 Camry SE
exclusive's Avatar
Gameroom cash: $305680
View exclusive's Photo Gallery
Here's a diagram to have them on with the parking lights. So this way if you forget to turn them off, they will switch off. If you want them on alone, wire the switch to the battery.
http://img219.imageshack.us/i/fogc.jpg/
Read here:
http://tl.acurazine.com/forums/showthread.php?t=794624
2011 Camry SE
|| Click my car below to see my thread ||
exclusive is offline   Reply With Quote
Old 03-20-2011, 12:15 AM   #3 (permalink)
So i Have to rewiring the fogs in order to make this mod? In corolla you only need to put a wire tap and connect to a ground place.
Check this out:
DIY: Disable DRL / Autolights and/or Independent Fog Light Mod w/ Pics
Old 03-20-2011, 09:28 AM   #4 (permalink)
CAMRY is my livelihood...
Kycamrymaker's Avatar
Gameroom cash: $118600
View Kycamrymaker's Photo Gallery
I PM'd you some pics. Good luck, let me know how it goes.
2011 TMMK SE V6, Leather, Nav, Remote start, 10,000k 55w HL, 8,000k 35w FL, 17% tint, LED conv.
Kycamrymaker is offline   Reply With Quote
The Following User Says Thank You to Kycamrymaker For This Useful Post:
streetuner (03-20-2011)
Old 03-20-2011, 10:31 AM   #5 (permalink)
molson.david's Avatar
Gameroom cash: $295153
View molson.david's Photo Gallery
Check this out:
will this work om Camry? do we have same connector behind glove box?
my fogs are independent, they sitting on independent wire harness with relay. power taken from fuse box and on/off switch installed on dash.
I don't care about DRL, but I would like to loose "auto" mode on my low beams.
anybody can confirm that gen 6 cutting "blue wire" will disable "Auto" mode?
IndianaBorn gen7 LE.
For sale gen 6:
MdxTSXr black shrouds 5K retro
OEM key with transmitter
2.4 transm.filter+gasket+WS.
2.4 K&N drop-in+cleaner and oil
molson.david is offline   Reply With Quote
Old 03-20-2011, 10:37 AM   #6 (permalink)
Rey
Pilot0617's Avatar
Gameroom cash: $148000
View Pilot0617's Photo Gallery
PM me some pics to on how you did these mod.
Pilot0617 is offline   Reply With Quote
Old 03-20-2011, 11:07 AM   #7 (permalink)
View streetuner's Photo Gallery
Can you pass that along to me too please??? Thank you!
streetuner is offline   Reply With Quote
Old 03-20-2011, 11:24 AM   #8 (permalink)
was playing on google and found posts about turning off autolight on Vibe and Tundra.
they both stats you need to cut yellow wire on DRL module and ground end which goes to the module.
they say you still will have DRL, but auto light will be off.
not sure where DRL module on camry, but sure will try this mode.
For sale gen 6:
Old 03-20-2011, 12:16 PM   #9 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $456050
View Luna2's Photo Gallery
You will put a dead short on the 15A H-LP fuse and stress the high power MOSFET transistor in the Light Control Circuit module, according to the diagram for the Gen 6 version. The module and fuse is located under the hood.
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is online now   Reply With Quote
Old 03-20-2011, 02:49 PM   #10 (permalink)
'11 Camry SE
exclusive's Avatar
Please share the pics.
I would think that rewiring them independently would be the best route, but that DIY posted seems interesting.
2011 Camry SE
Old 03-20-2011, 03:27 PM   #11 (permalink)
Just a pic of mine independent.
Old 03-21-2011, 04:42 AM   #12 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
^ did you just run your low beams off your fogs and your fogs off your low beams?
CamrySExxx is offline   Reply With Quote
Old 03-21-2011, 03:05 PM   #13 (permalink)
so, this wont work...
what about cutting blue wire, like on corolla?
For sale gen 6:
Old 03-21-2011, 07:00 PM   #14 (permalink)
Twin & (1 of 8)
Luna2's Avatar
No blue wire in the Gen 6. The Gen 6 uses a mosfet transistor, no relays.
There are two wires to activate the three functions.
1. Ground ONLY the Pink wire = low beams.
2. Ground the Pink AND the Violet wire together = high beams.
3. Ground ONLY the violet wire = DRL
4. Both lifted from ground = all off
MFG 02/25/2010
Stock, Shucks!
