2009 vs 2010 Camry (4 cylinder) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-20-2011, 03:59 PM   #1 (permalink)
View twocamrys's Photo Gallery
I have been looking at used 2009 and 2010 Camrys. Before I test drove any of them, I thought I would prefer the 2010 model since it has 11 more horsepower, a 6-speed transmission instead of a 5, and has stability control standard. But after driving them both, I am having trouble deciding which one would work better for me. The 2009 that I drove seemed to shift more smoothly than the 2010 model in traffic. Does the 2009 model have a smoother shifting transmission or is it possible that the 2010 model that I test drove just hasn't had the latest TSB done on the transmission? Although I like the extra horsepower and safety features on the 2010 model, I would purchase a 2009 model if it had a smoother shifting transmission. The car will be driven exclusively in town so it is important that I get a car that will drive well in heavy traffic. For those of you that have driven both models, which one do you think should drive better in town?
twocamrys is offline   Reply With Quote
Old 03-20-2011, 05:03 PM   #2 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $456050
View Luna2's Photo Gallery
There is a TSB out for the 2010 & 2011 for the transmission. Ask the dealer if it was applied or was the test vehicle you drove manufactured after the TSB date.
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is online now   Reply With Quote
Old 03-20-2011, 05:12 PM   #3 (permalink)
Gameroom cash: $169021
View Dave-o's Photo Gallery
I believe that the 2010 will drive smoother, with TSB or not, because it has dual variable timing as apposed to the 09's single variable timing
I own an 09 SE and usually drive my dad's '10 LE back and forth hauling stuff that needs the backseat folded down.
Although I feel the downshift between 20-30(his car's under the TSB), my dad's '10 acceleration and upshifting felt very smooth
Dave-o is offline   Reply With Quote
Old 03-20-2011, 05:28 PM   #4 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Mine don't.... not smooth at all.... I will get the TSB applied at my next service. And the dealer said the Power Steering whine is normal, I disagree......... Any body else with the I4 and have a PS whine?
MFG 02/25/2010
Stock, Shucks!
Old 03-20-2011, 06:49 PM   #5 (permalink)
View Robert1820's Photo Gallery
I own a 2011 base I4 auto and have driven several I4 5sp auto 2007-2009 Camrys ( I work at a shop and do tires & alignments). I think the 5 sp auto is a somewhat smoother trans and less shift busy. After 4000 miles, I have gotten used to the 6sp plus the shifting seems much better as the miles increase. I find the 2.5/6sp noticeably quicker than the 2.4/5sp. I read here about the 2010/2011 trans TSB but mine was made well after the cut off vin.
As for Luna2s' power steering whine question, I do get a whine in my car but I don't think it's from the ps. I believe it's from the trans but another 2011 I test drove sounded similar so I'm not worried by it. It is not as loud a whine noise as most newer Mercedes make!
Robert1820 is offline   Reply With Quote
Old 03-20-2011, 07:02 PM   #6 (permalink)
Twin & (1 of 8)
Luna2's Avatar
I had a dealer check the whine and by removing the serpentine belt it disappeared. I drove two I4 cars while on travel and the whine was undetectable. It sounds like the PS pump has a cavitation problem in my car. (A restriction problem in the pressure bypass/return line, most noticeable between 2000 to 2800 rpm.)
MFG 02/25/2010
Stock, Shucks!
Old 03-21-2011, 07:29 AM   #7 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
The 2az engine in the 2009 has been known for the head bolt issue at any time after 80k miles. So I'd go with the 2010 to be safe if I were you. My grandfathers 2011 shifts as smooths as butter. Though it's no where's close to my V6
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 03-21-2011, 02:39 PM   #8 (permalink)
i'm not certain, but I thought that the head bolt issue was narrowed down to the 2az's built between 2001-2004? I thought somewhere on the forum, someone said the problem of those headbolts were solved by adjusting the torque specs...trying to jog my memory...
Old 03-21-2011, 07:40 PM   #9 (permalink)
Pete Toyota's Avatar
View Pete Toyota's Photo Gallery
Does the TSB apply to 2011 6-speed automatics with the 4 cyl? My seems to skip gears when I gently accelerate.
Pete Toyota is offline   Reply With Quote
Old 03-21-2011, 08:23 PM   #10 (permalink)
Yes, the TSB applies to 2011 6-speed automatics with the 4 cyl. but it's dependent on the vin # and plant the car was built in. A quick search will find the tsb, it's posted here somewhere. My 2011 base Camry 4 cyl 6 sp. auto was very "busy" feeling at first, worst at lower speed/light throttle conditions. it has become much better now at 4,000 miles. Mine was built after the vin cut-off for the TSB.
Old 03-21-2011, 08:43 PM   #11 (permalink)
View JOET/CAMRY's Photo Gallery
It would be great to find out if this info (in red) is true or if all Camrys that had the 4 cylinder 2AZ-FE engine (from the years 2002 - 2009) had the head bolt issue.
JOET/CAMRY
JOET/CAMRY is offline   Reply With Quote
