2002 Camry Cat Converter Issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2011, 10:51 AM   #1 (permalink)
View jullissia's Photo Gallery
I have a 2002 Toyota Camry. My check in light has been going on and off for months. Sometimes it stays on and sometimes it goes off and comes back on in some days and sometimes months.It's time for emissions and the check engine light is on is there anything I can do to get it to pass emissions? Also the cat has already been replaced once by Toyota and the car has 185k miles on it! HELP!
jullissia is offline   Reply With Quote
Old 03-21-2011, 11:25 AM   #2 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1077958
iTrader Score: 7 reviews
Unhook the battery for 10mins it will reset the ecu.
Otherwise have it hooked up to a scanner and see what code it is throwing.
2002 Camry SE V6 "Snow White"
Old 03-21-2011, 11:51 AM   #3 (permalink)
It comes up p420, for a catalyst converter which has already been replaced once
Old 03-21-2011, 11:55 AM   #4 (permalink)
There is more than one on the car. There is 2 more i believe in the engine bay area. Could be one of them.
Old 03-21-2011, 12:12 PM   #5 (permalink)
I suspect it could. There has been some rattling noise near the timing belt which it is not the timing belt. How can I get the light to stay off until the driving cycle is complete?
Old 03-21-2011, 02:57 PM   #6 (permalink)
unhook the battery for about 10mins, it will reset everything (write down your radio presets etc) then hook it back up. the light should stay out for awhile longer.
Old 03-21-2011, 03:50 PM   #7 (permalink)
I also found some cat converter cleaner called Cataclean. Have you heard of it? I have seen some pretty good reviews for it mixed with techron.
Old 03-21-2011, 04:00 PM   #8 (permalink)
No sorry, never heard of that stuff.
Old 03-21-2011, 04:55 PM   #9 (permalink)
Toyota Parts since 1981
Gameroom cash: $148255
View DOHCammer's Photo Gallery
You can't do that to pass the emissions test. The test will be invaild due to 1 or more monitors not being ready. If it were that easy then everyone would pass emissions testing. I would try the chemical cleaning, it may work and its definitely worth a try. If a second cat has gone bad then there is probably an underlying problem such as need of a tune-up or oil burning.
05 Highlander V6 AWD
170K miles young
07 Camry SE V6 SOLD!!
TRD Dual Exhaust & Air Filter
DOHCammer is offline   Reply With Quote
Old 03-21-2011, 06:20 PM   #10 (permalink)
^ i know that.....
I was just telling him how to clear the code so the light goes out. Either way the problem has to be fixed.
