Paint Rock Chip Rusting?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2011, 02:49 PM   #1 (permalink)
Platium Member
Importz's Avatar
View Importz's Photo Gallery
Hey guys... There is a few rock chips on my car and there are starting to rust.. Is there an easy way to fix this at home or it needs to be taken to a bodyshop? Thanks...
Importz is offline   Reply With Quote
Old 03-27-2011, 06:16 PM   #2 (permalink)
molson.david's Avatar
Gameroom cash: $295153
View molson.david's Photo Gallery
get matching touch up paint.
use utility knife blade tip to clean rust away, works perfect, just dont do quick moves, do not scratch paint around. especially well clean border between good paint and rust.
touch it up with paint, cover all chipped area, do not go over good paint. let it dry.
touch it up again, as many times as it need to fill up chipped area.you should feel small bump over surrounding paint when you need to stop touching up.let it dry for at least two days.use wet 2000 sand paper to smooth chipped area, do not apply to much pressure.
then use buffing compound and soft cloth to shine sanded area.
IndianaBorn gen7 LE.
For sale gen 6:
MdxTSXr black shrouds 5K retro
OEM key with transmitter
2.4 transm.filter+gasket+WS.
2.4 K&N drop-in+cleaner and oil
molson.david is online now   Reply With Quote
Old 03-27-2011, 06:26 PM   #3 (permalink)
Gameroom cash: $101605
View kenny1773's Photo Gallery
Get on this as quick as you can. I had a small ding in the front lip of my hood on my 95 camry and it blew up to about nickel sized in a few years, all rust.
I lightly sanded the area with 600 grit sandpaper (cut circles out and glued to the top of a pencil eraser)
used Napa rust eliminator liquid on a small artists paint brush from a craft store
used touch up primer, again with the small artist brush (2 coats)
then used real Toyota touch up paint, again with the small artists brush not the brush in the container, put several thin coats until I had the height correct.
That held for several more years and never rusted again.
kenny1773 is offline   Reply With Quote
Old 03-28-2011, 12:01 AM   #4 (permalink)
Platium Member
Importz's Avatar
Thank you molson.david and kenny1773... I will give this a try and see how it goes
2011 Toyota Camry SE V6
Old 03-28-2011, 12:13 AM   #5 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
Wow, I have been doing it wrong. I just touch that area with paint and call it a day. No wonder the paint just comes off again.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
