Loosing alot of Coolant?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2011, 02:44 PM   #1 (permalink)
Platium Member
Importz's Avatar
View Importz's Photo Gallery
Hey guys... I have notice my car is loosing alot of coolant lately.. I just filled it up about 3 days ago and now its down to the min line again... I looked around and seems there is no leak or any drippage anywhere.. Any of you guys might know what the problem is? Thank you
2011 Toyota Camry SE V6
Importz is offline   Reply With Quote
Old 03-28-2011, 03:13 PM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
Have you checked the motor oil to see is it appears milky brown? The coolant has to go somewhere and if it not an external internal, then it's entering inside the engine. Headgasket maybe? Another possibility is a heater cord leak; dose it small sweet in the cabin?
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 03-28-2011, 03:19 PM   #3 (permalink)
Platium Member
Importz's Avatar
Hey.. The engine oil looks normal and there is no sweet smell from the engine anywhere..About checking head gasket and all that stuff I have no idea how... lol
Old 03-28-2011, 04:08 PM   #4 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
Check your water pump. It may be on its last leg.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 03-28-2011, 04:48 PM   #5 (permalink)
Gameroom cash: $202800
View Donald E. George's Photo Gallery
If you filled the overflow container up with the engine coolant low,the cooling system would pull the coolant back into the cooling system as it cooled. And it will keep doing this until the cooling sytem is full. Take the radiator cap off and see if the coolant is up to the overflow inlet. That quantity of coolant is bound to show up somewhere. Regards
Donald E. George is offline   Reply With Quote
Old 03-29-2011, 12:31 AM   #6 (permalink)
sxe-10's Avatar
Gameroom cash: $133154
View sxe-10's Photo Gallery
waterpump
sxe-10 is offline   Reply With Quote
Old 03-29-2011, 07:16 AM   #7 (permalink)
View Thunnda's Photo Gallery
My V6 did the same thing. Waterpump for sure. Toyota covers it under warranty, if you still have some remaining
White
SE V6
Thunnda is offline   Reply With Quote
Old 03-29-2011, 12:46 PM   #8 (permalink)
Platium Member
Importz's Avatar
Hey guys thanks for the info... I just took my car in today and hopefully they can fix this... I told them it might be the waterpump like you guys said and he said most likely it is.
