Need to buy today please. help. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-29-2011, 08:35 AM   #1 (permalink)
View 2009Camrysewhite's Photo Gallery
I have a 2009 Camry Se. I have the stock 17x7 Alloy wheels.
I want to put the widest tires I can on these rims.
Which one of these will work best.
Thank you.
235/50/17
235/55/17
245/50/17
245/55/17
2009Camrysewhite is offline   Reply With Quote
Old 03-29-2011, 08:56 AM   #2 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
stock: 215/55/17
width- 8.46"
diameter-26.3"
#1 proposed: 245/55/17
width- 9.65"
diameter- 27.61
#2 proposed: 245/50/17
width- 9.65"
diameter- 26.5"
#3 proposed 235/50/17
width- 9.25"
diameter- 26.25"
#4 proposed 235/55/17
width 9.25"
diameter- 27.18"
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 03-29-2011, 08:57 AM   #3 (permalink)
#3 is probably what you want but you need to check clearance with turning radius at its extremity. jack up your car and test it. simple.
Old 03-29-2011, 09:40 AM   #4 (permalink)
can i go with #2, For a wider look
Old 03-29-2011, 10:23 AM   #5 (permalink)
you can and slightly thicker tire than stock.
Old 03-29-2011, 11:15 AM   #6 (permalink)
Sorry, For the questions and I thank you for your help.
If I go with the 245/50/17. The diameter is about the same as stock. So I think I wont have clearance problems.
Will the 245 with protrude out side the rim lip, or outside the wheel well..
thanks again.
Old 04-01-2011, 09:08 PM   #7 (permalink)
View nagodesi's Photo Gallery
My local costco Tire said plus one would be a 235/50/17.. that is the max they would install. I'm afraid of rub on my stock 17" se wheels..
nagodesi is offline   Reply With Quote
